Old 10-09-2014, 04:21 PM   #1
Winterizing help - Air Compressors
I am looking a purchasing an air compressor to allow me to do my own winterizing. Can anyone help me understand how much air compressor I need to buy be able to successfully blow out my system.
I understand that I should not exceed 35psi into the trailer but how much airflow do I need, how big a volume do I need to get the job done. Will one the 'cheaper' 20 gallon direct drive units work or should I look at the more expensive, 30 gallon, belt driven 2 cylinder systems? These units will put out ~4-6.5 cfm of air at 40psi.
Any advice you experts might be willing to share would be greatly appreciated.
Gilm2113 is offline   Reply With Quote
Old 10-09-2014, 04:31 PM   #2
jtstromsburg's Avatar
I have a couple air compressors, both for construction type work not running so tools. They work fine. Most any compressor will work, but just take a bit longer if it constantly has to run to hold or build pressure. I use a little twin cylinder (no more than 10 gallon) direct drive one that was about $100 from Napa for the camper. Actually, it lives in the fiver basement.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-09-2014, 04:35 PM   #3
crunchman12001's Avatar
You really do not need an air compressor, you can just buy a Winterizing Kit for under $20.
I do blow my lines but also use anti-freeze with the winterization kit that sucks anti-freeze straight from the gallon jugs on the inlet side of the water pump. My unit takes less than 3 gallons.
A small compressor like this is what I use.
The smaller pancake ones like this would work too.
crunchman
2015 F-250 FX4
Old 10-09-2014, 04:38 PM   #4
I use an air compressor now but in the past have used a hand pump like I use to use as a bicycle tire pump.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 10-09-2014, 04:49 PM   #5
Air Compressors
JT, Crunchman & Big Paul --
Thank you for the quick feedback, I already have a small 2 gallon compressor that use for my tires and other things around the house. I was assuming that the volume wouldn't be big enough to do the job. It is very similar to what Crunchman linked to. I already have the winterization kit and the hand pump to hit the black tank wash. Even if I do buy a slightly bigger compressor I now know that I do not need one of those monsters in my garage!
Old 10-09-2014, 04:55 PM   #6
Gilm2113,
It would seem what you have will be fine. Glad to help and feel free to ask additional questions if you run into issues.
crunchman
2015 F-250 FX4
Old 10-09-2014, 05:07 PM   #7
Brother Les's Avatar
Be very careful using air pressure. I do not blow my lines out with air. Open all faucets and drain to low area drains. Isolate water heater (drained) and use water pump to fill water lines with RV antifreeze.
Brother Les
Old 10-09-2014, 05:11 PM   #8
Air compressors
Thanks Crunchman, I have always paid to have it done, but now that I have retired I thought I would give it a try. I have read all the threads on winterization and watched the videos.
We are getting our Lance trailer ready to trade in once our new Forester 2650S arrives mid next month. I am sure I will want to take the new unit out at least once when it comes so I will be prepared to do the new motorhome too once it arrives and before we put it to bed for the winter.
Old 10-09-2014, 05:13 PM   #9
Thanks Brother Les. I will probably start with very low pressure and work my way up but not exceed 30-35psi and then run the antifreeze in to the lines.
Old 10-09-2014, 05:20 PM   #10
Taranwanderer's Avatar
You don't need a ton of volume, there's not that much volume to the piping system. If your compressor will blow up a tire at 30 PSI, you should be good. Just do one faucet at a time (don't forget the toilet and outside shower,) and finish with the low point drains. If you live in the South, many people feel that's all you need to do. If you're up North, then antifreeze is a good follow up to prevent any "spring camper opening" surprises.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
winter, winterize
