Old 02-15-2015, 08:40 AM   #1
Winterizing - Help - By Pass Valve????
2010 Cardinal 3625 5th wheel. Where is the hot water by pass valve??? Tks!!!
Cardinal camper is offline   Reply With Quote
Old 02-15-2015, 08:45 AM   #2
KDHfan's Avatar
Go to YouTube and do a search for "RV hot water bypass valve"... Most campers are the same, or close enough that you can figure it out.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 02-15-2015, 08:49 AM   #3
KyDan's Avatar
If you know where your water heater is found on the outside of the trailer-
then figure the valve(s) are typically found on the other end of that.
Go inside and look for a panel with screws that you would remove
to access the rear of the WH.
If your WH is located right next to the pass thru storage then look in
there for a panel.
Peace!
Dan & Rita D
Old 02-15-2015, 08:53 AM   #4
Have you found the inside access point to your hot water heater? Usually there are arrows showing which way the valves should be facing for winterization. You want to make sure the valve allowing cold water ( should be a blue line ) into the water heater is turned to the opposite position from where you have been using it.
You will know when it is in the correct position when you open your hot water heater plug and water does not flow out at a high rate. Make sure you release the pressure relief valve first or you will be sprayed.
You are obviously lucky to be living in an area where you haven't had to winterize yet. It is 8* here in south Jersey this morning. UGH!
Good luck,
Don
Don and Michele
3 Adult Children - 5 Grandchildren
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
Old 02-15-2015, 06:21 PM   #5
Jim
on my 05 Cardinal, it is to the left bottom of the water tank. It is slightly hidden by one of the water pipes. Hope this helps.
JimP is offline   Reply With Quote
winter, winterize
