Old 11-20-2010, 01:16 PM   #1
Winterizing-How to find WH Bypass valve 2011 Salem FB 22 ?
Sorry if this has been covered, I tried searching the forum to no avail.
I've got a 2011 Forest River Salem 22FB (Northwest package) I'm (trying) to winterize for the first time.
Everything I read says to turn valve on the water lines at the back of the water heater to bypass it so I can run the anti-freeze thru the lines w/o antifreeze filling up the wh, but I can't find any access to the back of the water heater.
The fresh water tank in this model is located under the bed, and the water pump is also right there. I can see water lines going into the pump from the tank, and a line going out of the pump, and this line disappears down into the sealed floor, heading (I'm assuming back to the sinks, etc.)
Access to the water heater is via a outside panel at the back of the trailer. I've pulled the plug and drained the water heater tank, but no water lines in or out are visiable at this spot.
I've pulled interior panels (all I can find) and cannot get any access to the back of the water heater to find a wh bypass valve.
I think I'm missing something, but sure can't figure it out. Any ideas ?
Thanks.
ceduran is offline   Reply With Quote
Old 11-20-2010, 04:36 PM   #2
Found the bypass valves for the WH
They are located behind the drawers to the left of the bathroom, just on your left as you walk into the trailer. You have to remove one drawer to be able to reach them to turn them.
Never would have known this if we hadn't stumbled upon them !
Old 11-20-2010, 05:26 PM   #3
Villa Estate 392FLFB
The_Stuff's Avatar
lol. well now you know!
One state/province at a time!
The_Stuff is offline   Reply With Quote
