View Poll Results: Which method do you utilize to winterize your RV.
RV Antifreeze only 35 33.98%
Blow out lines 17 16.50%
Blow out lines and RV antifreeze 50 48.54%
None/Head south for the winter 1 0.97%
Voters: 103. You may not vote on this poll
Old 10-25-2014, 06:53 PM   #11
Average Joe
MrJoe's Avatar
Originally Posted by hockeytownmom View Post
I've never used the water bottle in the canister, just take the filter out and re-install the canister. What am missing here? Do you only do it to use less antifreeze?
Yes, just takes up space in the filter housing.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-25-2014, 07:16 PM   #12
mattb's Avatar
Drain freshwater and leave open, HW and bypass, Remove filter and cannister, Connect lines from filter together with a nipple and pump pink throughout with brass "T" ball valve adapter using pump. Make sure to fill P traps. Takes maybe 30 mins.
Pump Converter Winterizer Kit - Camco 36543 - Winterizing - Camping World.
mattb is offline   Reply With Quote
Old 10-25-2014, 07:59 PM   #13
asquared's Avatar
Well we winterized today and guess what, we discovered there was no filter in the housing. Guess I'll add that to my list. I did put the water bottle in there. I put a mix of water and antifreeze in the bottle.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-25-2014, 08:15 PM   #14
vasnipe's Avatar
Water bottle fill
Originally Posted by Mtelkman View Post
I just used a empty water bottle with the lid screwed back on. Why would you fill it with water?
I had a bottle collapse on me once. Maybe I got a weak one or something, but putting water in it stopped that from happening to me.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 10-29-2014, 07:43 AM   #15
jb3-7-77's Avatar
Here is what I did. First time winterizing.
Drain fresh tank and hot water heater. Bypass heater. Blow air (regulator at 45 psi, I think) through from city hookup through all faucets spray port. Dump a couple gallons of antifreeze into the freshwater tank and then turn on each faucet (cold first until pink then hot until pink) making certain adequate antifreeze is in the p traps.
I was surprised how much straight water came out of the faucets after blowing out all the airlines, my assumption is that it came from the water pump, but I could be wrong on that. On the air adaptor I used there was an orifice that looked like it would really restrict how much air could go through the system.
What is this bottle everyone is talking about?
2015 Cherokee Wolf Pack 21WP120
2014 Ram 1500 Outdoorsman
1986 Wife
2008 Pitter
2009 Great Dane
jb3-7-77 is offline   Reply With Quote
Old 10-29-2014, 07:52 AM   #16
Witch Doctor's Avatar
1986 Wife
2008 Pitter
2009 Great Dane
Look at post #11
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-29-2014, 07:58 AM   #17
jb3-7-77's Avatar
Right. Canister of what? The water filter? Is this a standard item on campers? I have no idea if I have a filter or not, and if I do it looks like I should have removed it before running antifreeze through my system...
Old 10-29-2014, 08:07 AM   #18
You might have one, if you do it will be by your city water hook up. The worst thing that will happen if you have one is that you will need to change the cartage in spring. You might have a problem getting all the pink stuff out of your fresh water tank. You might end up filling and dumping it about 10 times in the spring. Did you add some to your p-traps and gray and black tanks also? Another good thing is to put a little baby oil in your toilet, so your seal will stay soft. Maybe that is why you had so much water after you blew the lines out. I don't know much about your wolf pack. It gets pretty cold where you live, but pretty country.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-29-2014, 08:13 AM   #19
jb3-7-77's Avatar
Ten four! Thanks for the tips. Yes, I did put antifreeze in the gray and black water tanks, and I left a little antifreeze right on top of the toilet seal as well. Should I just dump the antifreeze and throw some baby oil in there?
Thanks again for the help.
Old 10-29-2014, 08:24 AM   #20
I would you don't want to stain your toilet and it will protect it and keep it soft, just enough to cover it won't hurt anything.
Coachmen M/H
Concord
2018 / 300 DSC
winter, winterize
