View Poll Results: Which method do you utilize to winterize your RV.
RV Antifreeze only 35 33.98%
Blow out lines 17 16.50%
Blow out lines and RV antifreeze 50 48.54%
None/Head south for the winter 1 0.97%
Voters: 103. You may not vote on this poll
Old 10-24-2014, 11:06 PM   #1
asquared's Avatar
Winterizing method poll
Ok it's that time of year again, so I thought a poll would help those deciding which method they want to use for wintering.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-24-2014, 11:18 PM   #2
vasnipe's Avatar
Drain at low point. Drain and bypass water heater. Drain water tank. Blow lines with low pressure air. Pull suction line off water pump, hook up tubing, stick end in jug of antifreeze and pump through each faucet. Burp fresh water inlet line and low point drains. Oh, forgot the house water filter. Pull and drain. Put 1/2 litre water bottle in filled with water. Reinstall before pumping. Uses less antifreeze that way.
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 10-25-2014, 01:40 AM   #3
asquared's Avatar
The water bottle filled with water doesn't freeze? We also usually do both methods. This will be our first year with the whole house filter. Does antifreeze hurt the filter or is it just a method to use less antifreeze?
2014 Sabre 34REQS-6
Old 10-25-2014, 04:38 AM   #4
Witch Doctor's Avatar
You will have install a new filter, the pink will never come out.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 10-25-2014, 05:23 AM   #5
Remove the (Element) and place (Plastic Bottle) in its place. The Filter (Canister) will be fine. Installing a (Whole house) Filter assy (OUTSIDE) would even be Better! Youroo!!
Old 10-25-2014, 04:15 PM   #6
vasnipe's Avatar
Water bottle in filter housing
Yes, you want to remove the filter element, I should have said that. That way you do not ruin the element. I got the water bottle idea here on the forum. It displaces that amount of antifreeze so you use a little less. This past winter was a bad one (by Virginia standards) with sub-zero temperatures. When I de-winterized in the Spring the bottle was intact.
Hope this helps some.
Chris in Virginia
Old 10-25-2014, 04:50 PM   #7
I just used a empty water bottle with the lid screwed back on. Why would you fill it with water?
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 10-25-2014, 05:55 PM   #8
Average Joe
MrJoe's Avatar
winterizing method poll
I blow mine out from the city fill, pump pink through city fill and drain for use later. Making sure pink flows from all faucets, showers and toilet. I drained all tanks, including HW, first.
Almost forgot, I drained the water from the pump.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 10-25-2014, 06:07 PM   #9
hockeytownmom's Avatar
I've never used the water bottle in the canister, just take the filter out and re-install the canister. What am missing here? Do you only do it to use less antifreeze?
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 10-25-2014, 06:25 PM   #10
deartruc's Avatar
Normally I'd do the pink stuff. Since I was picking the tt up from the dealer due to warrantee repairs, I figured I'd buy a couple of gallons. But, since they really messed up the repairs, and had to keep it to fix them, they said they'd do the winterizing. Hmm, after hacking up the bathroom door on the day of pdi, and now the horrible job they did with the stove, should I be buying some pex tubing and connectors over the winter for my spring startup?
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
winter, winterize
