Old 10-21-2010, 09:39 AM   #11
cmhbob's Avatar
Then again, it could just be a bad bulb.
Bob Mueller | Fulltiming family of 9 since Feb 2011
More About Me
cmhbob is offline   Reply With Quote
Old 10-21-2010, 10:44 AM   #12
I have an 84 mustang that required a box assembly at the rear because it has separate brake lights from turn signal lights(same brightness, on most cars, same socket). It is apparently some type of a relay, but I know it fixed my problem! I was towing a boat with a 4 pin, no 7 pin involved. Randy
Old 03-12-2011, 07:13 AM   #13
heytomgraywolf's Avatar
I was wondering what the difference is between a 6 way connector and a 7 way. I have a 2003 Sequoia and am getting ready to pull a small TT with electric brakes. I have the factory 4 way pigtail and will be buying an electronic braking module and I guess 7 way plug to mount back by the hitch. I was looking on etrailer.com and saw that they also sold 6 way round pigtail connectors. I am assuming most (all?) new TT's use the 7 way connector? I also pull a utility trailer and my 4000lb boat, but the boat uses surge brakes since it has to go in the water.
Any suggestions on good electronic brake modules? I have seen them range from $75 (probably too cheap) to $150 on etrailer.com. Any other good sources? I like how many of the products sold on etrailer.com have instructional videos.
Once I install the 7 way connector, I will get the adapater to adapt it back to 4 way when hooking up my boat or utility trailer since they just have the 4 way pigtail.
heytomgraywolf is offline   Reply With Quote
Old 03-12-2011, 07:28 AM   #14
Herk7769's Avatar
The difference between a 6 way and 7 way is the 7 way includes a line for backup lights.
You can easily buy a 7 way socket with a 4 way adapter. The one I got from U-Haul also has a 12 volt cigar lighter socket for accessories.
HAM CALLSIGN - KC3FFW
Old 03-12-2011, 07:47 AM   #15
KyDan's Avatar
You can't go wrong with a Tekonsha
Brake Controller | etrailer.com
Peace!
Dan & Rita D
Blue Ox WD hitch
