Old 08-13-2011, 10:08 AM   #11
Nigels's Avatar
Originally Posted by DAISY BOYKIN View Post
Would the bolt with the left & right hand threads screw into both of Nigel's
"jack screws"? Seems like you need left hand threads in one of the "jack screws". I haven't looked, does one have left hand treads?
Hi Sid
Each brace has a left at one end and a right at the other so when you twist the brace it either opens wider or closes smaller, My mod puts the braces back to back so you get either two lefts or two rights at the ends so the twisting will not work any more, Have a look you will see what I mean.
That doesnt matter though just wedge it in there by hand and it works a treat. Better do it quick before I get it patented
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 08-14-2011, 10:38 PM   #12
Wobble Fix
NIGELS remedy does work. I use the slide out locks at the rear levelers and a moving van cargo bar (which is the same identical instrument but longer) at the front legs of fifth wheel. Found it at a yard sale for a few bucks.
decooper3 is offline   Reply With Quote
5er
