Old 06-07-2019, 08:53 AM   #1
Wrinkle in ceiling panel
I was looking the other day and it looks like the vinyl on the ceiling panels has shrunk, or shifted and has taken on a wrinkled appearance at a couple of the joints. If I'm not mistaken, it almost looks like a small staple hole in one of the areas. There is a piece of vinyl about an inch wide that would cover the seams in the panels. Is there a way to either remove this piece, flatten out the ceiling material, and re-attach the strip, or loosen the strip on the edge, then push the material back into place?
It is not caused by water and is mainly a cosmetic issue. My biggest concern would be ripping the material, then I'd need a 2" wide cover strip..
TIA..
Camped: 2019 (Days/Nights) - 27/20
2018(D/N):24/17, 2017 (D/N):30/25, 2016 (D/N):32/23
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 06-07-2019, 09:04 AM   #2
I had a similar situation with the ceiling material looking wrinkled also. I just ignored it thinking that if I tried to correct it I would definitely damage it. I would occasionally notice it but accepted it. Just my opinion.
Jim & Kathy
Bailey, waiting at the Rainbow Bridge
Gracie, a rescued Beagle
2007 Chevy Tahoe
2008 FR Surveyor 233T
JimChow is offline   Reply With Quote
Old 06-11-2019, 02:42 AM   #3
CincyGus's Avatar
If it's minor wrinkles that are just bothering you, You may try some glue in a syringe, poke a hole in the wrinkled area, smooth it with a credit card or something firm like you were applying a decal and smooth out the wrinkles.
2015 GMC 2500K Denali, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart
CincyGus is offline   Reply With Quote
Old 06-11-2019, 05:53 AM   #4
Qicvick's Avatar
Mine is in shop right now to address this ( I hope it is just vinyl coming loose) it had several other issues but I was going to wait till a couple trips already planed but was afraid this could be water leaking so took it in again . Bought it 30th of March 2019 and it was in shop 7 weeks after being home 1 day, now itís back at shop after first camping trip 1 week and counting
Qicvick is offline   Reply With Quote
Old 06-16-2019, 08:41 AM   #5
I thought of that, but the issue I've got is the cover strip between two panels. The vinyl seems to be shrunk back from those. I'm not sure how they are secured to the ceiling, so that I can push it back under, without making a mess on the ceiling.
