Old 04-19-2019, 09:19 AM   #1
Zerks
I want to change the zerks on my Cedar Creek to a angle, I think 65 degrees. I took a zerk off that I used a 5/16 socket. Do I have to use a 5/16 zerk or can I use another size. Someone told me that the threads were different, SAE and metric. I know itís hard to get a grease gun on the straight ones
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-19-2019, 09:48 AM   #2
A32Deuce's Avatar
Just go to a NAPA store and have them match what you have with the angle you want. The other type parts stores may give you a blank stare!
A32Deuce is online now   Reply With Quote
Old 04-19-2019, 09:58 AM   #3
Thurman's Avatar
After working 42 years in the Industrial Maintenance field and after installing/replacing thousands of "zerk" fittings: I've never seen a 65* zerk fitting. They were either straight, 45*, or 90*. The part of the zerk fitting that fits into the hole for them are either straight, meaning that they press into the part, some have 1/8"-27 tapered pipe threads, some 1/4-28 or 5/16-24 machine screw threads for screwing in. Getting the female end of the grease gun onto a zerk fitting should not be hard at all. Maybe you just need to replace your's with new one's the same size. Grease will harden up within a zerk fitting if it is not used for some time.
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 04-19-2019, 10:16 AM   #4
Well the next time I visit the store Iíll take a picture and send it to you. Itís hard if you do not have enough room between the tire and the zerk. With my hand held grease gun I could get the grease in but now I have a air powered one
Iíll check NAPA today
Old 04-19-2019, 03:15 PM   #5
SilhouettePenny's Avatar
Take your zerk to any auto parts store, O'Reilly's has an assortment of straight, 45 & 90 degree fittings in one blister pack. Also pick up some J-B Kwik then simply clean, orient fitting to suit you and epoxy. Click image for larger version
2017 F350 Dually 6.7
2019.5 Hathaway
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 04-20-2019, 02:15 PM   #6
Itís hard getting grease in some fittings
Old 04-20-2019, 05:07 PM   #7
Just as confused as you
Scrapper's Avatar
The main problem I've see with zerks is the person doing the greasing doesn't clean the zerk off before attaching the grease guns coupler. Any dirt on the zerk gets pushed inside. As for using jb weld to hold the zerk in, with the zerks under a vehicle they need to be replaceable. A stone hitting the nipple will make it so the grease doesn't go inside. A good quality coupler is adjustable as to the amount or force it takes to snap it on/off the zerk.
You can buy replacement flexible hoses if the grease gun came with a steel tube.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 04-20-2019, 05:17 PM   #8
Iwannacamp's Avatar
Here you go....
2017 Puma 297RLSS
Old 04-20-2019, 11:36 PM   #9
Retired Old Fart
dward51's Avatar
Zerk fitting covers on Amazon! Yellow to match my Lippert EquaFlex. No dirt, no worries.
https://www.amazon.com/gp/product/B0040CWX7C
Just the 2 of us in a...
2015 Freedom Express 246RKS
2002 GMC Sierra 1500
dward51 is offline   Reply With Quote
