Old 01-21-2016, 03:25 PM   #1
Scokat's Avatar
13 RBQ front toilet...
2013 RBQ, had some relatives visit...needless to say the front toilet is clogged below the toilet. anything special i need to do, can i run a snake or no due to pvc
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
Old 01-21-2016, 03:37 PM   #2
dan-nickie's Avatar
Probably just toilet paper. I use a coat hanger straightened out.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 01-21-2016, 03:43 PM   #3
CAT-RN's Avatar
Did you have any hand wipes they could of put in there ?
Russell
CAT-RN is offline   Reply With Quote
Old 01-22-2016, 09:52 AM   #4
I assume you are talking about the Macerating toilet in the back? If so do not stick anything in it. It has a plastic macerator that you could damage. I had "someone " put butt wipes in mine. It stopped the pump from turning. I had to remove the toilet( very easy) put a garbage bag over the bottom and take it outside. I then took the pump apart and removed the wipe from the pump. Put it all back together and all is good. It's a messy job and you will need some good latex gloves and a place to take it all apart.
Make sure all who use the back toilet that nothing but waste and TP can go in it.
Old 01-22-2016, 11:57 AM   #5
Yuk
Paulie Boy is offline   Reply With Quote
Old 01-22-2016, 12:37 PM   #6
CAT-RN's Avatar
Sounds a bit messy--not understand the latex gloves--hard to work with gloves on !!
Russell
Old 01-22-2016, 01:17 PM   #7
The gloves save time when you are done with the job. I can be difficult to get the poop out from under your fingernails. Gloves sent mandatory but like I said poop under the fingernails.
Old 01-22-2016, 01:20 PM   #8
CAT-RN's Avatar
Your toothbrush take care of under the finger nails!!
Russell
Old 01-22-2016, 01:22 PM   #9
It's really not that tough a job. I had to call a repair guy to help me carry the toilet out. I had it unhooked and after looking at the pump I decided it was an outside job. I'm not able to lift that much so it cost me a hundred dollars to have him help me carry it out and back in. I did everything else. A cordless drill helps a bunch as there are ten or so screws that hold the pump to gather. I took it apart and the sanitary wipe was jammed between the impeller and the pump housing.
Old 01-22-2016, 01:24 PM   #10
Russell
It got most of it but not all. I was able to get the rest out just by shaking hands with all my friends!
