Originally Posted by JohnKen
I'm seriously considering the purchase of my first motorhome - a 2008 Berkshire 360QS (with the optional Mercedes diesel engine). The coach is a real beauty, but it is in need of new tires.
Current tires are Michelin XRV 255/80R22.5 LRG's (on aluminum rims). If I buy the coach, should I replace these with the same series or are there better options available now? I would welcome comments and suggestions from current owners or FR/Freightliner reps.
Thanks in advance for any light you can shine on this topic.
John
You can go with 275/80R22.5 LRG. Some of us have already done that to help an over-weight problem on later model 390's. The bigger tires SHOULD fit your aluminum rims with no problems.
You should also consider the fit in the wheel wells, and finally your speedometer/odometer/computer will need to be re-programmed.
I'm NOT a FR or FL rep. Only way to know for sure if you need bigger tires would be to weigh the coach.
Boowho??
