Old 07-13-2018, 04:01 PM   #1
2016 Berkshire 38A - batteries drain when stored
Batteries drain when stored
smorcos is offline   Reply With Quote
Old 07-13-2018, 04:02 PM   #2
My batteries drain when stored even though I turn both house and RV batteries off
Old 07-13-2018, 05:15 PM   #3
Mmnsc's Avatar
If you leave you inverter on when both battery switches are off it will still drain your your house batteries. Just turn off the inverter on your control panel
Mmnsc is online now   Reply With Quote
Old 07-13-2018, 06:49 PM   #4
Dragonship Captain
Oscarvan's Avatar
Yes, inverter get's 12V directly from house battery. Even "off" there may be a slight draw to keep the "on/off" circuitry energized. Only removal of the big inverter fuse (next to house batteries) or disconnecting one of it's leads will ensure that there is no draw.
There should be a schematic on the inside of the compartment door.
Best thing is to have a battery tender and if that is not an option disconnect the negative leads from the bank or remove the two big fuses. (one house, one inverter).
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 07-14-2018, 09:51 AM   #5
Thank you, this is very helpful
berkshire
