Old 10-14-2015, 07:16 AM   #1
baddmann's Avatar
28" Replacement Wiper Blade part number
I researched this and with trial and error I finally found the correct brand/part number that fits. I have been using these for over a month now, and they work perfectly.
Bosch Microedge 40728 28" wiper blade
Each blade comes with a bracket/clip that will work on our wiper arms or you can remove the bracket/clip from you old wiper arm and use it. The old one will "click out" and then "click in" to the new blade. (The blades are wide enough to fit on our wiper arms)
These blades are $13-$16 and are readily available at Autozone, Walmart, or Amazon.
Also, keep in mind that these blades are 4" shorter, so you will lose 2" on each end. After you put them on, you don't notice the difference in length.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 10-14-2015, 07:07 PM   #2
Campin Cajun's Avatar
Can we sticky this thread?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-14-2015, 10:33 PM   #3
baddmann's Avatar
I hear ya! Thanks! I hope this info will help everyone.
Brian and Kelly
Old 10-30-2015, 02:22 PM   #4
I only use my wipers when it rains so I think 4" missing that's a SAFETY 'I DOM'
outloud is offline   Reply With Quote
Old 10-30-2015, 08:56 PM   #5
2013 Berkshire 390 BH-60
Jersey Guy's Avatar
I just put 32" blades on mine. They were Tru Vision, identical to the original ones.
Mike
2013 Berkshire 390BH-60
Jersey Guy is offline   Reply With Quote
Old 10-30-2015, 11:37 PM   #6
baddmann's Avatar
Yes. Those are the recommended replacement. However they are expensive and not easy to find if you are in a rural area.
The blades I suggested are inexpensive and can be purchased at Walmart/Autozone if you are on the road.
I drove through rain all last weekend and you can't tell the difference. They work great.
Brian and Kelly
Old 10-31-2015, 11:51 AM   #7
I have not found the WB anywhere else but CW. They are very expensive and not that great of quality. I will switch to badmans find when I need them. If you are staying with the 32" I would suggest buying a spare as you can't find them at a truck stop. I tried last year and had to switch the drivers/passenger to continue our trip. Passenger had no blade on her side.
Old 10-31-2015, 02:49 PM   #8
Garrette's Avatar
Check out the Valeo brand wiper. I like them.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 11-01-2015, 12:53 PM   #9
baddmann's Avatar
Is there a particular size/model number that will fit the Berkshire wiper arms?
Brian and Kelly
Old 11-01-2015, 01:20 PM   #10
accumack's Avatar
Look at their Rv in their avatar not a Berkshire so most likely none will fit. I tried the Michelins won't fit just barely too narrow to fit our arms so I'll get the Bosch 40728.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-01-2015, 11:31 PM   #11
Motodad's Avatar
I put rain-x washer fluid in mine as well as all my vehicles. Drove 100 miles in the berk today and it was pooring the whole time. Never really had to turn wipers on. Every now and then I spray the windshield to add more rain-x. I swear by this stuff. 👍👍👍👍
Motodad is offline   Reply With Quote
Old 11-02-2015, 09:10 AM   #12
X2
Paul
Paulie Boy is offline   Reply With Quote
Old 11-02-2015, 09:30 AM   #13
accumack's Avatar
Rain X is great stuff.
Ham KG5LTL.
Old 11-05-2015, 11:21 PM   #14
I had a malfunction on my passenger side blade. It was a Truvision Tv832 that I bought from a local vendor about a year ago. The blade it self was fine having been covered when parked. The problem was the adapter they used warped and the part that clips into the arm wouldn't hold. So the adapter that the Bosch includes doesn't even clip into the arm, it just kind of slides over it. So you can probably rig something to make it stay like I did. Or you can use the existing clips if yours are still are still usable. The visibility reduction isn't any major problem for the driver but it is noticeable on the passenger side.
I also use the Rain X wiper fluid. It is good stuff.
Jeff and Elaine
2011 Berkshire 390QS
2 Lab Dogs-Eros and Star
1 Cockatiel-Lucky
dogsgocamping is offline   Reply With Quote
Old 11-13-2015, 08:20 AM   #15
baddmann's Avatar
UPDATE:
I just got back from a long journey with lots of rain. No issues at all with these blades.
Brian and Kelly
Old 02-03-2016, 01:35 PM   #16
Subsailor's Avatar
Originally Posted by baddmann View Post
UPDATE:
Thanks for the tip on these Brian. I just ordered some for my '13 Berk. The ones that are on my rig now are making that real annoying noise and not wiping very well. -Glenn
Glenn and Darcy
2018 Berkshire 39A
2016 Jeep Wrangler Unlimited/Blackbear (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 02-03-2016, 01:46 PM   #17
BamaBob's Avatar
I put rain-x washer fluid in mine as well as all my vehicles. Drove 100 miles in the berk today and it was pooring the whole time. Never really had to turn wipers on. Every now and then I spray the windshield to add more rain-x. I swear by this stuff. ��������
Originally Posted by Paulie Boy View Post
X2
Paul
X4. We used Rain-X in Germany and it ~literally~ was a life saver!
I just saw where Rain-X is making Wiper Blades with rain-x embedded - sure wish they made them in MoHo sizes!
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
replacement
