Old 07-02-2015, 03:51 PM   #1
30 amp service
What's the downfall of plugging into a 30 amp service.
Paulie Boy is offline   Reply With Quote
Old 07-02-2015, 03:56 PM   #2
oldkeywest91's Avatar
One A/C at a time
oldkeywest91 is offline   Reply With Quote
Old 07-02-2015, 03:57 PM   #3
tmmar's Avatar
You couldn't run both AC's at the same time. You would also be limited as to what other electrical appliances you could run when you had 1 AC going.
Tom and Margaret
2014 Berkshire 390bh-60
Old 07-02-2015, 04:35 PM   #4
Thanks. Haven't had to do it yet. Just wanted to be aware of the downside. Thanks to all for the input.
Old 07-02-2015, 06:24 PM   #5
edgewant's Avatar
A few weeks ago I camped at a Corp of Engineers Campground here in Tennessee. The power post had a bad breaker on the 50 amp side so I had to use the 30 amp. I have 13.5K ac units and was able to run both on 30 amp. But when we tried the microwave it popped the breaker. So I think if you're careful you can get away with running both ACs.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 07-02-2015, 09:49 PM   #6
Campin Cajun's Avatar
You can run both AC's on 30 amp, but you won't be able to run anything else like microwave.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 07-02-2015, 10:00 PM   #7
If both start up at the same time mine will trip the breaker. As a result I will only run one to be sure I don't do damage to them. It can't be good to have them shut down while trying to start.
Old 07-03-2015, 08:58 AM   #8
Get the cord that plugs into a 30 amp and a 20 amp and has a 50 amp plug on the end... Priceless
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 07-03-2015, 12:32 PM   #9
ceedog's Avatar
Like jcowles said , get yourself a cheater box.
They won't work (as a rule) on GFCI outlets.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 07-03-2015, 04:39 PM   #10
Gottawonder's Avatar
I have a 50 to 30 amp "dogbone" and an adaptor for that to plug into a 15amp 3 prong socket at the house. I avoid extension cords but can keep 1 a/c going while I have the rig at home. I plan to put a 30/50 amp box outside, but I've plugged up like this without issue. I (RIGHT OR WRONG) go in and change the charger/inverter shore power setting to 5 amps. My assumption (RIGHT OR WRONG) is that the battery charger won't try to draw heavy from the wall socket.
2014 Berkshire 390RB-60
2014 Jeep Wrangler Unlimited
Roadmaster Falcon A/T tow bar
Gottawonder is offline   Reply With Quote
service
