Old 05-13-2015, 07:00 PM   #11
dan-nickie's Avatar
Originally Posted by ernest917 View Post
Oldkeywest91....
Exactly how do I set up the gen auto start.... Wasn't aware you could do that....
I don't know about your year model 08 is it?
On ours the Magnum ME-RC has a button called AGS to get to the programming.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-14-2015, 08:05 AM   #12
JTN8's Avatar
Is your fridge the residential or dual gas and electric? If its the residential, your batteries may hold up about two days with the fridge on but if it's the dual electric or propane, the batteries should hold up about a week if you're not running anything else.
Jason
Old 05-14-2015, 10:24 AM   #13
tnbendr's Avatar
[QUOTE=tmmar;862497]tnbendr,
What brand of refrigerator is in your coach? If you have a residential refrigerator (ie. Whirlpool), that only runs on electric and not on propane.
Also, congrats on your new coach and welcome to the Forums.
Tom[/QUO
Thank you tmmar! Yes I have a residential fridge and just realized the real difference between that and an RV fridge. I'm good now, just bought a 100' heavy duty 12 gauge ext cord and plugged into house while we are getting ready...once were out on the road I can let the systems work as they are designed.
tnbendr is offline   Reply With Quote
Old 05-14-2015, 01:29 PM   #14
oldkeywest91's Avatar
to run ags press AGS button then select,then turn dial to select Start Volt,select the start volt you want the gen. to start and then press select.You can also start Air Cond.the same way to keep MH cool if pets left and the temp gets to hot...Have a good day.
oldkeywest91 is offline   Reply With Quote
