Old 05-12-2015, 11:49 PM   #1
tnbendr's Avatar
38A
Anyone out there with a 2015 Berkshire 38A?
tnbendr is offline   Reply With Quote
Old 05-13-2015, 07:47 AM   #2
oldkeywest91's Avatar
YES,what would like to know
oldkeywest91 is offline   Reply With Quote
Old 05-13-2015, 12:29 PM   #3
tnbendr's Avatar
Can I leave my Magnum ME-RC at the factory settings for now until I understand how it functions? Because it seems like my house batteries run out quick when I'm not hooked to shore power and all I have on is fridge.
Old 05-13-2015, 02:45 PM   #4
dan-nickie's Avatar
What would you call quick? I did a test on my 390rb and the best you can expect it between six to eight hours. That assumes that your rig has four 6 volt batteries.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-13-2015, 04:45 PM   #5
I agree between 6-8 hours. You could set up the magnum to auto start your generator if the battery voltage falls to whatever low voltage setting you select on the magnum. I believe you select the AGS and then set your preferences.
Old 05-13-2015, 05:23 PM   #6
tnbendr's Avatar
Thanks Dan and OldKey, I do have 4 bats and it did last that long, guess I thought with only the fridge running it would last longer. I could also run the fridge on propane correct?
Old 05-13-2015, 05:26 PM   #7
tnbendr's Avatar
How long have you had your 38A oldkey?
Old 05-13-2015, 05:35 PM   #8
ernest917's Avatar
Oldkeywest91....
Exactly how do I set up the gen auto start.... Wasn't aware you could do that....
ernest917 is offline   Reply With Quote
Old 05-13-2015, 06:09 PM   #9
tmmar's Avatar
tnbendr,
What brand of refrigerator is in your coach? If you have a residential refrigerator (ie. Whirlpool), that only runs on electric and not on propane.
Also, congrats on your new coach and welcome to the Forums.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-13-2015, 06:57 PM   #10
dan-nickie's Avatar
We were all thinking you had a Residential Fridge that did NOT run on propane.
Dan
Old 05-13-2015, 07:00 PM   #11
dan-nickie's Avatar
Originally Posted by ernest917 View Post
Oldkeywest91....
I don't know about your year model 08 is it?
On ours the Magnum ME-RC has a button called AGS to get to the programming.
Dan
Old 05-14-2015, 08:05 AM   #12
JTN8's Avatar
Is your fridge the residential or dual gas and electric? If its the residential, your batteries may hold up about two days with the fridge on but if it's the dual electric or propane, the batteries should hold up about a week if you're not running anything else.
Jason
Old 05-14-2015, 10:24 AM   #13
tnbendr's Avatar
[QUOTE=tmmar;862497]tnbendr,
Tom[/QUO
Thank you tmmar! Yes I have a residential fridge and just realized the real difference between that and an RV fridge. I'm good now, just bought a 100' heavy duty 12 gauge ext cord and plugged into house while we are getting ready...once were out on the road I can let the systems work as they are designed.
Old 05-14-2015, 01:29 PM   #14
to run ags press AGS button then select,then turn dial to select Start Volt,select the start volt you want the gen. to start and then press select.You can also start Air Cond.the same way to keep MH cool if pets left and the temp gets to hot...Have a good day.
