Old 06-17-2015, 10:52 AM   #1
38A Cruise control
We're finding that with cruise control engaged, we are losing 5-8 MPH Going up a hill and then gaining that much on the downside of the hill. If we manually downshift or disengage with the pedal, we can maintain speed. Seems as though the cruise does not downshift soon enough up hill to maintain current speed. Doesn't seem like we should gain speed going back down.
The Ramsey's
Carrollton, TX
2015 Berkshire 38A
2012 Jeep Liberty toad
Eustuss is offline   Reply With Quote
Old 06-17-2015, 11:16 AM   #2
We pick up our 2016 38a Friday!! Our first coach and super excited. Anything we should look for during our initial walk-around that you've discovered?
ntoensing is offline   Reply With Quote
Old 06-17-2015, 01:13 PM   #3
dan-nickie's Avatar
Do you have the transmission in economy mode?
Also, what is your speed and how big is this hill?
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-17-2015, 01:23 PM   #4
JTN8's Avatar
I usually keep the cruise set but manually down shift if I see a decent hill coming up. Coach maintains speed just fine.
Jason
Old 06-17-2015, 05:56 PM   #5
The trick is downshifting early before you start to lose momentum. It's a 33000 lb MH not a 4000 lb car. You need to be proactive. Don't be afraid to down shift. You are only giving the transmission permission to downshift and it won't let you do anything that would hurt the motor or transmission.
Old 06-18-2015, 05:22 AM   #6
I-RV's Avatar
When going up-hill, besides watching the speedometer I get on the gas pedal and watch the tachometer. When the rpm's start to fall, I generally downshift manually (using the buttons). At the top of the hill, I hit D (drive). On major down-grades, I touch the brakes when gaining speed to engage the exhaust brakes and the use the brake as needed.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 06-18-2015, 11:31 AM   #7
tnbendr's Avatar
Speaking of exhaust brakes, if I don't have the switch on and I'm at speed, say 65, now I come up on a downhill grade, can I engage the switch at that speed? To save on using brakes.
Ben & Michelle
2015 Berkshire 38A
2005 Jeep Wrangler toad
tnbendr is offline   Reply With Quote
Old 06-18-2015, 11:39 AM   #8
tmmar's Avatar
Yes. No problem engaging the exhaust brake at speed.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-18-2015, 11:43 AM   #9
tnbendr's Avatar
To long to list right now ntoesing, but I will share 3 major issues;
- Kitchen sink drain hose behind FP was melted do to contact with back of heater (major leak)
- then found heater itself was not secured in its mounting (that took a day to fix
- major daylight from under kitchen slide (factory has new seal fix for that, but you may already have that seal on the 2016)
Ben
Ben & Michelle
2015 Berkshire 38A
