Old 03-25-2016, 01:32 PM   #11
15berkxl's Avatar
Originally Posted by Phil57 View Post
The CO2 sensor should turn off the LP and to my knowledge has nothing to do with the reset on the water heater. I would guess that in the time it took to open the water heater door and hit the reset the sensor cleared and LP was restored. Someone feel free to correct me. I'm not aware of any reset on the sensor other than the silence button which I guess would be a reset.
Thinking this through as I type is the reset on the water heater sensitive to LP supply being interrupted? So if the CO sensor turns off the LP do you need to push the reset button on the water heater to restore LP to the heater?
Phil to the best of my knowledge the limit is only high temperature but if flow was not high enough it could have tripped it and like you said the LP issue was unrelated to WH.
Wayne
Wayne
15berkxl is offline   Reply With Quote
Old 03-25-2016, 01:38 PM   #12
15berkxl's Avatar
Also, something I found last year was the little black tube that sticks through the cover of the WH take it off and make sure it is not plugged. If it is WH will not light.
Wayne
Wayne
Old 03-25-2016, 02:55 PM   #13
Wayne
I had mine fail to light after a heavy rain. The water filled that tube and "plugged " it. Odd chance it happened one time. I really like this Atwood WH.
Old 04-21-2016, 09:38 AM   #14
38A tankless water heater
I have a 2016 Berkshire 38A, love it!! Was traveling to Florida with my family and the dog and the CO2 detector went off twice, not sure why but because i had the dog, who freeked out, i disabled the CO2 detector. Without knowing that disabled the propane so no hot water, no stove top. Had to re connect than open outside panel and hit small reset button. Im posting this because this forum is how i figured out the problem. I read where a person's CO2 detector went off from hairspray and they had to re set the water tank.
Hope this helps someone.
smorcos is offline   Reply With Quote
Old 04-21-2016, 09:58 AM   #15
tmmar's Avatar
smorcos,
Congrats on your new Berkshire and welcome to the Forums!! Hope you have many fun, memorable and trouble free trips with it!
This is what this forum is all about. Helping each other solve any issues that may arise and sharing the solution with others so that it will help them should they encounter the same problem.
Tom and Margaret
2014 Berkshire 390bh-60
Old 04-21-2016, 10:04 AM   #16
AquaMan's Avatar
Congrats on new coach, smorcos! Certain cleaning products and Lysol disinfectant spray will also set off CO detector.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 04-22-2016, 08:52 AM   #17
CO2
I agree that the CO2 sensor does not turn off the tankless water heater but it does disable the LP. Prior to reconnecting the CO2 sensor the water heater was turning on but There was no pilot light and therefore no hot water.
Old 04-27-2016, 11:43 AM   #18
RKNOLA's Avatar
Hi smorcos,
We have a 2016 38A too! It is really a well made, sturdy coach. We love it! Welcome to the forum. Lots of friendly folks around here always willing to help.
Karen
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 04-27-2016, 04:45 PM   #19
bb920's Avatar
After having to reset my Atwood WH a number of times I believe due to low temperatures. Its exposed to the cold weather, and when it drops to below 32 degrees, it will light to prevent from freezing, but with no water flowing. Thus, causing it to trip and need to be reset. (Me thinks)
Anyway, I'm thinking of drilling a hole right over that darn reset switch, so I don't have to remove the cover to push the reset.
Now I will also tell you that since I am not camping in freezing weather, it has not happened any more. But still...
Also, on a side note, after owning the MOHO for 3 days, one of the small pin's at the bottom of that Atwood door fell out, the dealer fixed that one, while looking a the reset issue, then the other one fell out at my next camp site 500 miles away. I came up with a fix, but REALLY!!
Even with these few issues, I'm still LOVING my BERK.
Bill & Kay
Green Bay, WI
2016 FR Berkshire 38A
bb920 is offline   Reply With Quote
Old 04-28-2016, 10:26 AM   #20
Contact Mitch Wirt at FR. I've heard that the Atwood reset issue may require the unit to be replaced.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
heater, tank, tankless, water, water heater
