Old 01-12-2015, 11:18 AM   #1
baddmann's Avatar
390BH-60 Fifth gear issue
When I am taking off from a stop or accelerating from 30mph, I have an issue when the coach shifts from 4th to 5th. Once it shifts to fifth, the turbo boost drops to 5-8lbs and the Berk stops accelerating. No matter how much as I press the pedal, it barely maintains speed in the 55mph range on flat ground. Once I go downhill and get to 60mph it shifts to 6th gear and the boost kicks back in. I can manually put it in 4th and get to 60 and then put it back in auto and it does better.
Does anyone have this issue? Have you noticed anything similar?
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 01-12-2015, 11:39 AM   #2
JTN8's Avatar
I personally have not had that issue ever with my 2014 390BH (340).
Jason
Old 01-12-2015, 11:44 AM   #3
baddmann's Avatar
Jason
Ok.
I am just checking before I take it to Freightliner.
Thanks!
Brian and Kelly
Old 01-12-2015, 11:45 AM   #4
Ford Idaho's Avatar
Fault codes?
Fuel filter/s replaced?
Old 01-12-2015, 11:50 AM   #5
baddmann's Avatar
Originally Posted by Ford Idaho View Post
Fault codes?
No Fault codes and I replaced the fuel filters 2k miles ago. It has been doing this since I bought it. It pulls like a freight train until it hits 5th and then you almost experience weightlessness as the acceleration stops.
I have been telling myself it is some kind of transmission program to protect 5th gear, but we went to the Orange Bowl in Miami and it was very annoying.
Brian and Kelly
Old 01-12-2015, 11:50 AM   #6
JTN8's Avatar
It almost sounds like your computer needs to be re-flashed or programmed. If it's working fine in all the gears except 5, then I would think the computer is cutting your turbo back in 5th gear for some
Reason.
Jason
Old 01-12-2015, 11:52 AM   #7
baddmann's Avatar
I tend to agree with you.
I just wanted to see if anyone else had this issue before I take it to Freightliner. It's only 30-45 minutes from me, but it is a hassle to take it in.
Brian and Kelly
Old 01-12-2015, 11:58 AM   #8
Ford Idaho's Avatar
If you pull the dipstick for the transmission and sniff the oil does it smell like it is burnt?
Old 01-12-2015, 12:58 PM   #9
dicky1243's Avatar
It sounds to me like turbo-under boost sensor is faulty
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 01-12-2015, 01:00 PM   #10
baddmann's Avatar
I have not smelled the fluid. I'll go the storage and check it.
Looks like I need to take it to Freightliner.
Thanks for the replies.
Brian and Kelly
Old 01-12-2015, 09:32 PM   #11
Campin Cajun's Avatar
I would call the FL hotline, see if they can recommend anything, then take it to an Allison shop and have them check the CPU on the transmission.
I didn't have this problem but I had a communication issue with mine. It was covered under warranty.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-27-2015, 11:23 PM   #12
I had the identical problem in mine. All boost would drop in my 4 to 5 shift. Freightliner was able to diagnose it in about 10 minutes back to a simple programming error. Call freight liner corporate for assistance because my local service center was confused until they got direction from FL. Once FL was involved, my coach was ready in minutes. Glenn Collins at FL was the one who helped me. 800-385-4357. Hope this helps. Call me if you need my info so Glenn can pull up my case for reference. I'm at 3102613443. -brian
bborder is offline   Reply With Quote
Old 01-28-2015, 12:16 PM   #13
baddmann's Avatar
Excellent. Thanks! I will take it in next week and report back
Brian and Kelly
Old 03-21-2015, 09:52 AM   #14
baddmann's Avatar
Brian: Thanks for your help. It was a simple programming error. "Powertrain Protection" was enabled and should be disabled on motorhomes. Once that was corrected, it drives like a champ. Boost in 5th gear is back!
Brian and Kelly
390bh
