390BH Accent Lights and Dimmer
the control panel next to the TV has a space for accent lights and a dimmer. They are currently just capped / blank.The wiring and switches are already there. You can see them if you look inside the entertainment center towards the panel / thermostat area.
Does anyone know how to finish the install of these? What lights,if any, are they currently tied to?
I assume that these are here because it is a "standard" install. Maybe this same panel is used in the Charleston, I dont know.
