Old 06-22-2010, 08:24 AM   #1
2008 390BH
390BH Accent Lights and Dimmer
the control panel next to the TV has a space for accent lights and a dimmer. They are currently just capped / blank.The wiring and switches are already there. You can see them if you look inside the entertainment center towards the panel / thermostat area.
Does anyone know how to finish the install of these? What lights,if any, are they currently tied to?
I assume that these are here because it is a "standard" install. Maybe this same panel is used in the Charleston, I dont know.
justinph is offline   Reply With Quote
Old 06-22-2010, 12:21 PM   #2
2011 Berkshire 390bh
wnytaxman's Avatar
On our unit these are the overhead lights with dimmers in the Living Room area. I'm not sure why you wouldn't have something there. Did you check with your dealer?
wnytaxman is offline   Reply With Quote
Old 06-22-2010, 03:49 PM   #3
tmmar's Avatar
Mine are capped also. I think that is because I have fluorescent lights in the living area and they are not dimmable (sp?). Are the light in your living area fluorescent also?
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-23-2010, 07:15 AM   #4
2008 390BH
tmmar, mine are fluorescent. My coach is same year as yours
wnytaxman, are yours fluorescent? You ahve a 2011. Thought maybe they have LED now.
Old 06-23-2010, 07:33 AM   #5
wnytaxman's Avatar
Mine are all LED lights. They really give off a real nice soft light and you don't get the heat like you do from other kinds of light.
Old 06-23-2010, 10:06 AM   #6
2008 390BH
i have thought about switching some of mine over to LEDs. wating for the bulb prices to come down a bit. hopefully the dimmer will work then.
Old 06-23-2010, 10:22 AM   #7
tmmar's Avatar
Justin,
Don't know how you would change over to LED's. You would probably have to change the fixture as well and I don't know how that would work with the padded ceiling. Are there LED's in the shape of the fluorescent bulbs currently in fixtures?
Tom and Margaret
Old 06-23-2010, 10:37 AM   #8
2008 390BH
yes. not sure if this is the right size but it gives you the idea.
LED Tube Bulb LED-2FRX 2ft 9-watt Fluorescent Retrofit Bulbs LED Lighting at LEDUBulbs.com
Old 06-23-2010, 10:45 AM   #9
tmmar's Avatar
Justin,
Nice. Did you log in and get the cost of the bulbs?
Tom
ps- I just sent you a pm also.
Tom and Margaret
Old 06-23-2010, 10:59 AM   #10
2008 390BH
did not get $.
i sent respons eto your pm.
Old 05-03-2013, 11:04 AM   #11
silver's Avatar
Follow up to Accent lights
Did you ever find a location to tap into the accent lighting in your Berkshire?
silver is offline   Reply With Quote
Old 05-03-2013, 04:08 PM   #12
silver's Avatar
Accent Lights
I to would be interested if anyone knows.
390bh, berkshire, surveyor
