Old 11-11-2014, 08:37 PM   #31
Alex, There are temp "probes" in each zone for the single thermostat.
Zone one is front and zone 2 is rear.
2014 Berkshire 400bh.
2014 Jeep Rubicon unlimited Sent from my iPhone using Forest River Forums
Glenn
2014 Berkshire 400BH
2014 Jeep Rubicon Unlimited
grt1014 is offline   Reply With Quote
Old 11-11-2014, 09:00 PM   #32
Glenn, I see that you have 2014 400BH and you said that you have one thermostat. On previous page JC mentioned that he has 2 thermostats and also 2014 400BH. Was it an option or late introduction?
Thank you,
Alex
AlexG is offline   Reply With Quote
Old 11-11-2014, 09:03 PM   #33
I don't know for sure. I bought mine in February 2014. I saw some of the manufactured dates somewhere and I think it was made in October 2013.
Glenn
Old 11-11-2014, 09:14 PM   #34
Thank you for reply
Old 11-11-2014, 10:08 PM   #35
One thermostat , 2 zones. Controls heat pups, heat and cool in zone 1 and cool only zone 2, and both furnaces, zone 1 and 2. Also controls fan speed and if you push the right button it will tell you the ambient temp in either zone. Actually not a bad thermostat especially compared to those on my boat, a 2005 model now happily serving it's second owner.
Dan
2015 Entegra Anthem 450HP-1250ft lbs of torque
2015 Jeep Grand Cherokee
Roadmaster Falcon 2 All Terrain
SMI Air Force 1
seeg is offline   Reply With Quote
Old 11-12-2014, 08:32 AM   #36
JTN8's Avatar
The thermostat can control any and all systems in each zone. What determines what shows up on the screen is how the dip switches are set up on both of your AC's.... My coach has dual 15K heat pumps so my Tstat controls them both. Most Berkshire owners only have 1 heat pump (fwd) and a regular AC (rear) so the heat pump option will not show up on their Tstat because the dip switch for zone 2 on the rear AC is not selected for heat pump.... If you look on dometic's website there are a lot of instructions about the Tstat and airconditioners and proper settings
Jason
Old 11-12-2014, 09:00 AM   #37
tmmar's Avatar
There is a remote sensor in the rear bedroom that is hooked up to the thermostat in the living area. It will keep what ever temperature that you set on the thermostat for zone 2 (rear bedroom). The living areas temperature will be controlled by the thermostat which is in the living area.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 11-12-2014, 10:02 AM   #38
ernest917's Avatar
My 2008 has two heat pumps as well.... Only one furnace though.....
ernest917 is offline   Reply With Quote
390bh
