Old 05-05-2013, 05:02 PM   #1
Himcules's Avatar
3rd tv input selector
what does your 3rd tv input selector control?
my 1st tv is the main mid ship mounted screen.
the 2nd tv is the bedroom tv.
the 3rd tv is FOR SURE NOT the outside unit.
the outside unit has it's own antennae which is not the HD boosted like the and rest of the coach. it's RCA jacks are connected to the jensen car stereo unit under it. no interaction with any of the other systems inside the coach. this is strictly by itself...
i did find rca jacks in the middle front cabinet above the driver's seat (the old place where tv's were mounted). perhaps the 3rd selector controls that?
i'm interested in a way to re-wire for HDMI cabling and upgrading to an HDMI selector... we'll investigate further to see how the current RCA cables are ran/tied off and see if i can use them as pulling cords to snake the new HDMI cables through...
also, can you get surround sound to work through the HDTV antennae source? or is this only when you play a DVD?
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-05-2013, 07:04 PM   #2
I've been waiting for 6 months for FR to provide me a wiring diagram of the COAX and other cables for the entertainment system.
I pitched the selector box as well as the DVR Player/Surround sound system and put in my own. This allows me to control everything with a single remote and no need to get up from the sofa to push buttons on the selector box
I can flip between OTA Antenna, DishNetwork, BlueRay player and a Western Digital media player all from the single remote. The only thing I don't have working on it is the bedroom TV. Still working on that.
I was aghast at the fact that FR used the OLDEST video/audio standard out there (composite video) for cabling purposes, when HDMI has been popular for at least 5 years. At least the could have used component, no?? Most all new electronics these days don't even have composite anymore.
Like you, I used the old composite wires to pull HDMI's.
IF anyone has succeeded in getting that diagram from FR please post it. Even knowing where the roof-end of the "satellite prepped" would be wonderful.
Boowho??
boowho is offline   Reply With Quote
Old 05-05-2013, 07:38 PM   #3
Campin Cajun's Avatar
The third TV would be the cockpit TV.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 05-05-2013, 08:57 PM   #4
Himcules's Avatar
Boowho??
thanks boowho. that's the plan. i do want a hdmi 3x4 or 4x4 source selector. i need to find the limits of hdmi cabling and will then plan for this upgrade.
thanks campin cajun. that's what i thought. useless where it's ran now....
Old 05-05-2013, 10:38 PM   #5
I bought a cheap RCA surround sound system at Walmart, about $150 if I remember. Even though a low end unit, the sub-woofer will rattle the whole d*** coach if I crank it up.
It has 4 HDMI inputs and 1 HDMI output. That's what I used to replace my source selector. It's great for a single TV.
Still working on how to configure for a second TV. But that's not high on my priority list at the moment. Probably just going to run a coax from the Dish receiver directly to the rear TV and that's it.
Never watch OTA TV or movies in bed anyhow; just Dish Network. Nor do I have an outdoor entertainment center.
For the actual remote I use a Phillips Pronto. However, those are pretty much becoming obsolete; there are good android apps that run on a tablet (or even a smartphone) and provide the same functionality as the Pronto.
Many of the newest TV's, Blueray players, etc are able to accept remote commands through a WIFI interface in addition to the "old fashioned" infrared. My guess is that in a few years, infrared controls will only be seen in museums.
Boowho??
Old 05-05-2013, 10:53 PM   #6
Berkshire 390QS
NO3putt's Avatar
Think the 3rd would be if you had gotton the optional outside entertainment center. Ours did have a coax cable outlet in the first left hand bay and ac outlet witch we installed a flat screen TV in. Works great if using antenna, cable or satellite dish with the exception that you have to change channels for the dish inside.
NO3putt is online now   Reply With Quote
Old 05-05-2013, 11:56 PM   #7
Himcules's Avatar
no, i have the outside tv. the 3rd selector is not hooked up to it at all... as i said in the first post, the outside tv is only hooked up to the jensen car radio/dvd player underneath it. i did have to reconnect the tv's rca audio output to the radio so we can hear through the car speakers mounted right there.
i'm finding more and more things just not done properly by the factory.. some simple things, some not so simple.. just not the craftsmanship i expect for this price tag... and to say that this is a low end/mid level coach and that's normal craftsmanship is unacceptable in my book. competent craftsmen would not make these kind of mistakes...
Old 05-06-2013, 12:02 AM   #8
Himcules's Avatar
Boowho??
google hdmi source selector. they have many 3-4 input and 2-3 output selectors.
however, if you want to use the remote, you will need to also run the infrared pickup lead as well. otherwise you control everything from the midship area and go into the room you want to watch and just sit...
if you need to have remote control abilities with your sat tv in the bedroom, then the best bet is to run coax to it so you have a dedicated set top box to control with the remote in that room.
i just cancelled all my cable and sat tv subscriptions. this is a vacation vehicle for us, not our primary home so i try to make my family spend more time outdoors when we go camping instead of staying indoors and relying on electronics. hell, i don't let them start a fire with a match... i make them do wood prep, make their own kindling, and use a firesteel.. even my youngest at 7 years old knows how to make a substainable fire by herself where most adults need gas/camping fuel, match and/or paper to light a fire... too much tv makes them incapable of basic survival skills so this is a very low priority for it.. just an annoyance it isn't done right...
Old 05-06-2013, 12:08 AM   #9
Berkshire 390QS
NO3putt's Avatar
Got me wondering, mine has cables out the selector in the 3rd switch but never bothered to trace them to as where they go. Might be a project for tomorrow. The quality of workmanship could be much better along with the dealers service department. Many things when we purchased new should have been fixed at factory or dealership before it was offered for sale in the first place. If the auto industries were like the rv manfactures we all would be riding bikes around. Just my 2 worth.
Old 05-06-2013, 12:16 AM   #10
Himcules's Avatar
go look in the middle cabinet up front in the cockpit.. mine has the rca connectors there for a tv... also some wierd power plug (looks to be 12v). that is where mine is but i have not verified signal gets to that place...
