Old 10-05-2016, 02:36 PM   #1
40BH Height with airbags dumped
Does anyone know the coach height when the airbags are deflated? The spec says 12'5" to the top of the ac units when in travel. I'm trying to figure out if a 12' door is tall enough in my building if I dump the air. I have plenty of height once inside the building.
1kayak4sdl is offline   Reply With Quote
Old 10-05-2016, 03:23 PM   #2
Berkshire 390QS
NO3putt's Avatar
My Berk dosen't go down 5", maybe 3" or 4". But I do have a different model
2015: 188 days, 2016: 72 days,
Skip
Old 10-05-2016, 03:30 PM   #3
dan-nickie's Avatar
Is there a way to dump the air without the Jacks going down?
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 10-05-2016, 03:31 PM   #4
dan-nickie's Avatar
I would suggest actually measuring rather than going by the specs. Either way I don't think you'll be able to fit it under a 12-foot door.
Dan
Old 10-05-2016, 03:43 PM   #5
ceedog's Avatar
You can dump the air by lowering the jacks. After they're down, retract them.
The big question is how are you going to move your coach without starting the engine.
Once the engine is started, the air bags will start to inflate.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 10-05-2016, 03:56 PM   #6
7 Year Class A RV'er
Don't forget that unless you have an absolutely flat drive into the garage, your coach is going to be higher in the rear when you back it in due to the slope. You've also probably got a 1" lip at the door threshold, so the 12' "door" may only have an opening height (clear) of about 11'-11" or so
2015 Legacy SR340 360RB with 2014 Wrangler Unlimited Toad
Gigi, Poppy and Sadie the Jack Russell (all 14 lbs of her)
Old 10-05-2016, 08:50 PM   #7
Thanks guys. I don't have the MH yet. My wife and I have decided on the 40BH and haven't had the time to locate one yet. I know I have a 12' opening. Trying to decide if I need to rework the opening for more clearance or not. A friend is able to dump his airbags and slowly back straight under his door. Hoping to do the same.
Old 10-05-2016, 09:54 PM   #8
Texas Realtor's Avatar
My doors 14 ft as no way for me on 12s
Texas Realtor is offline   Reply With Quote
Old 10-06-2016, 11:06 AM   #9
Go Seahawks!
Subsailor's Avatar
Like the others I don't believe there is anyway you will be able to negotiate a 12' door even if you were to find a way to back it in with the air bags deflated. We have different coaches, but I have measured mine both fully inflated and "flat" and noted only about 3 1/2 inches difference. My satellite dome is 12' 9'' (inflated) so I round up to 13' for good measure. I got real sensitive to height issues after owning 3 5th wheels. Those darn things are tall.
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 10-06-2016, 12:02 PM   #10
Sounds like I will need to add a taller door in the gable end of my building.
airbags
