Old 01-29-2019, 12:20 PM   #1
CZNEDY's Avatar
7 Pin Connection Fail
Up until this weekend, everything on my harness from the MOHO to the Jeep has been working fine. This weekend, no directional's or brake lights on the Jeep. I took the BlueOx harness home and it checks out. I'm going to work on checking the MOHO harness and connections next. Anyone have any suggestions on where to look? (2018 34QS). Thanks,
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 01-29-2019, 12:24 PM   #2
cavie's Avatar
I would start at the tail of the MH. If that's ok go to the Toad fuse box. Directional and breaks are the same circuit. 1 fuse. Well, they used to be
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-29-2019, 12:46 PM   #3
llr
How is the harness wired to the taillights? Neither of mine went through the toad fuse box.
I assume taillights are ok since you didn't mention them.
I would start measuring voltage on the back of the coach, if good then the end that plugs to the Jeep. If not good the the coach fuse panel.
Do the brake and turn signal lights on the coach work? and
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 01-29-2019, 12:49 PM   #4
CZNEDY's Avatar
The Toad lights all work and the MOHO lights do too. It may be a fuse on the MOHO end. I will take some readings at the 7 Pin on the motorhome and see what I get.
Old 01-29-2019, 01:34 PM   #5
Who Dares, Wins
doc73's Avatar
I would also suspect a fuse for the trailer wiring.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-29-2019, 02:09 PM   #6
Vince and Charlette's Avatar
Had the same thing happen and my son discovered the connector pin hadn't been pushed into the receiver all the way. It sure seemed like it when I tried it, but it wasn't until we began troubleshooting that we found it. So, I trust that it is as simple as that for you.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 01-29-2019, 02:12 PM   #7
rsdata's Avatar
pick up a can of this to protect the electrical connecting surfaces in the plugs...
Too much of anything is bad, but too much good whiskey is barely enough. Mark Twain
2014 Shamrock 183
Old 01-29-2019, 02:17 PM   #8
Director, FROG
F.R.O.G.'s Avatar
When Cindy and I had that issue, we turned the cable between the MH and the car around. There is absolutely no reason that I know of that it should make a difference, but it did. The contact grease/spray might also help.
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 01-29-2019, 02:27 PM   #9
If you start looking for fuses on the MOHO end, note that the coach fuses are independent of the 7-pin harness fuses. That is the way newer vehicles are wired and it was done as a safety issue. Seeing that neither side of the toad brake/turn lights are functional, your looking at a common cause-which would be a fuse. If one side or the other was working on the toad, it would be a wiring issue or a bulb. Also, on an outside chance, it may be possible that the bulb filaments are bad or the bulb sockets are corroded.
Have you used something like the Blue Ox wiring harness to the toad rear lights to segregate it from the Jeep, or is it wired to the OEM jeep wiring?
PenJoe is offline   Reply With Quote
Old 01-29-2019, 03:26 PM   #10
Our glitch was the bottom taillight on the passenger side wasn’t tight in its socket. Sometimes it’d work, sometimes do what your is, and sometimes when turning the right turn signal on it would wig-wag the jeep taillights (but not the coach). About drove me silly trying to figure it out as everything else checked out fine with a meter. Last time it did it i slapped the taillight (this time the bottom bulb didn’t light as we did our pre-move check. It all started working. I managed to slip my arm behind the rubber flap between the radiator and rear wall and managed to find the loose part. As best as i could
I refitted the bulb and the fitting into the tail assembly. It’s worked ever since, knock on wood.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
