Old 07-21-2012, 09:59 PM   #1
A/C
When I run my A/C in zone 1 I get cold air out the vents in zone 2. This makes the zone 1 unit run nonstop when we have the door closed in our bedroom when we have guest. Is this normal. I would think the bedroom vents would just be supplied by the A/C zone 2.
Old 07-21-2012, 10:18 PM   #2
TURBS's Avatar
Make model and year would help.
Old 07-21-2012, 10:24 PM   #3
2011 390rb Berkshire.
Old 07-21-2012, 11:11 PM   #4
kingwood390bh's Avatar
I'm on my second multi ac motorhome(Damon and Berkshire) and on both there is a central channel for the ducting. There appears to be no barrier between the ducting in zone one and two. I don't know the reason for this, but there must be one.
kingwood390bh is offline   Reply With Quote
Old 07-22-2012, 04:00 AM   #5
As a work around we opened the air dump on the grate to keep both units cycling all night. We use the MH 90% of the time with just the two of us so having just Z1 running at night is fine. It's a lot quieter that way.
Old 07-22-2012, 10:04 AM   #6
tmmar's Avatar
Yes-- it is normal. I think it is because the ducting is not segregated between the front and rear at all. I have noticed the same thing with my coach.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 07-22-2012, 10:37 AM   #7
CLASS "A" Senior Member
cfsoistman's Avatar
Same thing in the Georgetown line. I think they did this to enable AC to flow through the whole coach in the event you only have 30 amp service and could only run one AC unit at a time. We set our living area unit a little low during the night so it runs and air still flows into the bedroom but without the louder noise of the unit inside the bedroom running.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-22-2012, 03:20 PM   #8
accumack's Avatar
We have a 2011 390-rb-340 Berkshire. I believe it's setup that way because only zone 1 is a heat pump while zone 2 isn't.
accumack is offline   Reply With Quote
Old 07-22-2012, 04:46 PM   #9
tmmar's Avatar
On my coach, both units have heat pumps.
Tom and Margaret
Old 07-22-2012, 06:20 PM   #10
accumack's Avatar
Yours looks like it is a bunk house ours has 1 1/2 baths and really only sleeps 2 although the sofa has an air matress. The rb stands for rear bath. I don't know if 2 heat pumps were an option as we bought our unit off the lot and got what I think was an awesome deal.
