Old 01-09-2016, 02:14 PM   #1
oldkeywest91's Avatar
Cool A/C Heat on dash
There are many new 38A on forum so my question is this.With the dash control in the dash/floor position is your A/C compressor kicking in.Finding it is a problem in this position to keep hot air supply fighting the A/C and it only happens then.Had to have compressor replaced by FL.when it seized up coming home from FR factory for other repairs.FR said it was a FL problem but they say FR problem.So I am trying to see if it is a problem with switch or just the way designed.
oldkeywest91 is offline   Reply With Quote
Old 01-09-2016, 03:13 PM   #2
ceedog's Avatar
If I understand the problem correctly, you want to blow hot air thru the floor vents & the dash vents at the same time. When doing so you are not using your A/C compressor.
When directing air (other than using your A/C) you are engaging a solenoid that directs air to the floor. dash, or defroster vents.
When using your A/C, air is directed thru the dash vents only.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 01-09-2016, 03:22 PM   #3
No,when i use the dash/floor position as in picture the A/C comes on.I am not in the A/C position as pictured.the A/C is on the far left of the switch.
Old 01-10-2016, 01:49 PM   #4
ceedog's Avatar
Does the A/C compressor come on when you direct air to the floor vents only, or to the defroster?
Old 01-10-2016, 04:47 PM   #5
yes to defroster,no to just floor or just dash.
Old 01-10-2016, 09:05 PM   #6
Tombsy's Avatar
In my truck the ac comes with the defrost it's supposed to help dry the air. I have to turn my fan off and on to reset it. Not sure if it's anything similar.
Sent from my iPad using Tapatalk
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on custom trailer.
60 days fishing/camping so far
Tombsy is offline   Reply With Quote
Old 01-10-2016, 09:16 PM   #7
Typically the A/C will run when in defrost modes (or obviously A/C mode). If it runs constantly in other modes theirs likely a fault in the HVAC control.
'14 XLR 395AMP
'16 Ram 3500 DRW, 6.7 cummins w/aisin trans and 4.10 gears
ykdave is offline   Reply With Quote
Old 01-22-2016, 07:41 PM   #8
BobbyJ
Bobbyj's Avatar
This whole set-up is similar to the first auto-dash designs. My 61 Impala might have had this design. When you are in A/C, or possibly defrost position, that is the only time you should get A/C. In the position shown you should only get heat to the dash and floor vents.
Bobbyj is offline   Reply With Quote
Old 01-23-2016, 09:04 AM   #9
RKNOLA's Avatar
our 38A is a 2016 and the A/C panel is different than the one shown in the pic. Ours has a separate compressor button. Sorry I couldn't be of more help.
Karen
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 01-23-2016, 12:18 PM   #10
Karen, can you post a picture?
JIM9091 is offline   Reply With Quote
