Old 05-01-2014, 02:27 PM   #11
Originally Posted by dan-nickie View Post
I'm afraid not.
I'm out of ideas.
Looks like a trip under the slide is due to investigate pinched wires or start pull ing the outlets and check for loose or disconnected wires. MAKE sure you're unplugged from shore power.
Old 05-01-2014, 02:33 PM   #12
I think the plug in the back left compartment is a GFI. Check it.
Old 05-01-2014, 05:53 PM   #13
dan-nickie's Avatar
I checked the plugs in the compartments. none with a reset button on it.
Ah, might be daisy-chained through the outlets. Thanks for the tip on that one.
Sent from my DROID BIONIC using Forest River Forums mobile app
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-01-2014, 05:55 PM   #14
dan-nickie's Avatar
I also have been looking around underneath. Doesn't have a bundle of cables hanging out underneath the slide like many I have seen. The cables are run along the frame rails and are pretty much hidden from view.
They seem to enter the coach up through the basement. I'm wondering where the slack is that they would need when the slide moves? On top of the floor, but under the slide?
Dan
Old 05-01-2014, 06:33 PM   #15
Would start pulling the receptacles themselves and check the wires. They are notorious for falling out of the push in clips.
Old 05-01-2014, 07:45 PM   #16
dan-nickie's Avatar
Yep, I figured that was pretty much my next option. Thanks for all the pointers.
Dan
Old 05-01-2014, 08:17 PM   #17
Dan do you have a volt tester that sound an alarm when current is present I don't know what they are called but that would tell you if you have elec in the line. I know this isn't very clear sorry. I was thinking of other possible things to check and wondered if you checked the reset on the inverter?
Old 05-01-2014, 08:42 PM   #18
dan-nickie's Avatar
I am using a simple volt meter. Doesn't have sound.
I think the converter and inverter are combined. I looked at it but didn't see any breakers or buttons to reset.
It does have 120 volts at the breaker in the breaker box.
And the inverter powers the televisions okay.
Dan
Old 05-01-2014, 08:46 PM   #19
On mine it's a rocker looking switch. I had it trip several times awhile back and it would take our a couple if outlets. I don't have the same inverter as you but mine is in top and like I said it looks like a small rocker. My issue was most likely overloading outlets.
Old 05-01-2014, 08:48 PM   #20
It has to be something simple that tripped. If it was working one min and not the next. I always look for the worst thing and forget or overlook the obvious. Hopefully you will find it soon.
slide
