Old 03-18-2015, 05:43 PM   #1
A/C Question
Our Berkshire came with 2 13500 A/C units. Is it feasible to replace them with 1500s, and would it make a difference?
RLHAMILTON is offline   Reply With Quote
Old 03-18-2015, 06:14 PM   #2
tmmar's Avatar
Yes, you can replace the 13.5k btu AC's with 15k btu AC's and I believe that it would make difference. How much of a difference depends, naturally, on the outside temps. If you do a lot of camping in very warm climates, the change will help.
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-18-2015, 06:19 PM   #3
Jerry01's Avatar
Just my opinion but I would try changing just one at a time and see if that helps. That would save you some money. Jerry.
2005 GMC Sierra 2500HD, Duramax 2WD CC/SB
2013 Cardinal 3030RS full body paint
B&W Companion slider, air bags, EFI Live Custom tuning by So Cal Diesel
Jerry01 is offline   Reply With Quote
Old 03-18-2015, 06:35 PM   #4
JTN8's Avatar
I ordered mine with 2 15k heat pumps and in the summer with temps in the upper 90's, I'm able to keep the coach in the low 70's... The difference between the 13.5's and the 15's is the temperature of the air coming out of the vents. The pressure of the air is the same but the temp is lower.
Jason
Old 03-18-2015, 07:08 PM   #5
We are in Fort Myers FL and it's been 90 the last 4-5 days. We have no shade and have two 13500 AC units. We have been able to keep the temp inside at 73-75 all day. Things we have done awning on all windows. Sunscreen on windshield and door also drivers window. Sunscreen on the slide out side windows. We keep our big awning out also. One thing I read about but haven't tried was to pains the skylight with a plastic white paint. Reports are that keeps the bathroom cooler. The front catches lots of sun so the sunscreen is very important.
Old 03-19-2015, 02:19 PM   #6
Thanks for the responses.
Old 03-19-2015, 05:18 PM   #7
2014 360 QL
po 185's Avatar
phil
can you send me a picture of the awnings on the windows? and where do you get them installed
2014 360 ql
po 185 is offline   Reply With Quote
Old 03-19-2015, 07:12 PM   #8
Originally Posted by po 185 View Post
phil
PM sent
Old 03-20-2015, 04:56 PM   #9
I replaces my front ac heat exchange when it died on warranty. Paid the difference to upgrade to 15.
I had looked at putting a third unit in the kitchen vent.... was told that the roof was not designed for.weight.
Possible problem with 2 15s is power. Especially if.you only hame.30 amp
lefaivre is offline   Reply With Quote
Old 03-20-2015, 04:58 PM   #10
TURBS's Avatar
You can't run 2 15k units on 30 amp.
