Old 11-24-2015, 10:24 PM   #41
Man, That seems like a great idea.
James & Amy
2016 246RKS Freedom Exp.
2015 Ford F150 King Ranch SuperCrew
It's a nice night for an evening
woodpile is offline   Reply With Quote
Old 11-24-2015, 10:26 PM   #42
Have you used the original pads over the years or replaced ever so often?
James & Amy
Old 11-24-2015, 10:44 PM   #43
2011 Berkshire 390BH
Superchief's Avatar
Same pads and in great shape after 4 years.
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 11-24-2015, 10:46 PM   #44
Craig do you remember what the pad cost?
Old 11-24-2015, 10:55 PM   #45
accumack's Avatar
I think it is this one.
Rubber Mat, Black, 4 ft. x 6 ft. - For Life Out Here
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 11-24-2015, 11:07 PM   #46
Superchief's Avatar
Yes that is the one. 4 years ago it was around $35, if I remember correctly.
Craig
Old 11-24-2015, 11:09 PM   #47
Originally Posted by accumack View Post
Thanks. Great idea. Thanks Craig.
Old 11-25-2015, 04:59 AM   #48
CAT-RN's Avatar
A little frustrated (need a little venting time)
Here are some that I made.
RussellClick image for larger version
Name:	ImageUploadedByForest River Forums1448445572.859535.jpg
CAT-RN is offline   Reply With Quote
Old 11-25-2015, 11:41 AM   #49
BamaBob's Avatar
Glenn, I have the old style level pad foots and have used them extensively for the past four years on all kinds of terrain. Early on, I went to Tractor Supply and purchased a 4 foot by 6 foot heavy rubber mat used by farmers for cow and horse stalls.
Craig & Glenn,
One of the Mods that is popular with the FR 5er owners is taking 2 pieces of Diamond Plate and sandwiching a leveling block between them, pop riviting the contraption together then bolting that to your landing gear and rear stab jacks.
I wonder if something similar would work as a permanent solution for the Berk? Then you would not have to stow them in the basement (or crawl under to get them )
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 11-25-2015, 05:07 PM   #50
I-RV's Avatar
RussellAttachment 94961
I always use wood planks under my jack pads. I believe I have the old style and just maybe I have been delaying the punch-through because my jacks leave impressions of the nut on the wood, This means that all the weight is not on the pad's seating ring for the piston. Should there be punch-through, the piston would not be heading for china if the pad was on dirt.
Hank
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 11-25-2015, 05:59 PM   #51
accumack's Avatar
You'll know when they punch through you'll be looking for the truck that hit you. LOL
Ham KG5LTL.
Old 11-30-2015, 10:33 AM   #52
baddmann's Avatar
Exactly. I have had 1 punch through and it was pretty violent. Rocked the coach so bad it broke the closet doors. Scared the crap out of us! (It was a rocky, uneven surface)
They only replaced that 1 jack pad but the others are still working fine.
If I am on a rock/uneven surface, I put wood down. If it a is flat concrete/asphalt I just use the jacks.
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
vent
