Old 03-16-2019, 12:27 AM   #1
Welshes's Avatar
Access to engine
We have a '16 34QS and I can't find access to the top of the engine. I've removed two screws and can't find others...I know they are there...somewhere in the closet or next to the bed. Any ideas?
Welshes is offline   Reply With Quote
Old 03-16-2019, 12:59 AM   #2
Dragonship Captain
Oscarvan's Avatar
My layout is different... but maybe the same design "philosophy" applies...
After removing the screws I have to slide the hatch rearward about an inch and THEN the aft edge lifts up. There's a lip that holds the front edge in.
Maybe this helps.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is online now   Reply With Quote
Old 03-16-2019, 05:21 AM   #3
dan-nickie's Avatar
Only 2 screws in my RB. But getting it unstuck the 1st time was a bitch.
Tile floor BTW.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 03-17-2019, 10:54 AM   #4
Welshes's Avatar
Thanks...I'll check it out after the snow melts ;-)
Old 03-17-2019, 11:01 AM   #5
western NC mountains!
formerFR's Avatar
My Palazzo probably has an access under my bed platform, though I've never had any reason to actually see - maybe I will now ; ) (mine is carpeted, though, nice)
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 200w/10amps mobile SOLAR
90,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
Old 03-18-2019, 09:10 AM   #6
Welshes's Avatar
There's some maintenance required eventually, a filter to change on top from what I'm told. Yes, ours is carpeted with only the two screws holding it down so I'm anxious to find a way to slide the cover after removing them.
Old 03-18-2019, 05:30 PM   #7
formerFR's Avatar
Exclamation
decided to finally look for mine today, after 4 1/2 years and over 92,000 enjoyable miles, although I've HEARD it many times...
below the front-facing master bed platform,
under the carpeted storage area...
remove 5 screws and the plywood access piece...
to 'see' the engine... wow, I DO have one!
it's dusty, but it still works.
[this may be one of the few diesel coach floorplans that don't have the typical 'step up' near the rear of the coach, or in the rear bath or rear closet, as our headboard is at the rear of the coach, and the bed is essentially right over the engine.]
Name:	engine access bedframe.jpg
ID:	199082   Click image for larger version
Name:	engine access open.jpg
The Turners
Old 03-18-2019, 06:48 PM   #8
Dragonship Captain
Oscarvan's Avatar
I bathe mine.....
Old 03-19-2019, 11:41 PM   #9
Welshes's Avatar
Originally Posted by Oscarvan View Post
I bathe mine.....
A beauty...nice job!
Old 03-19-2019, 11:42 PM   #10
Welshes's Avatar
I bathe mine.....
Now where does that filter go?
