Old 10-03-2015, 12:45 PM   #21
tmmar's Avatar
Originally Posted by BendOrLarry View Post
Why waste it?
If you don't put enough into the traps and you have a problem, then it is not a waste. It's only a $1 or $2 so why not just be safe and pour it down the drains?
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 10-03-2015, 12:46 PM   #22
We drive our Berk to Yuma to winterize it.
Boowho??
kaymfischer is offline   Reply With Quote
Old 10-03-2015, 12:49 PM   #23
tmmar's Avatar
Boowho??
Unfortunately I don't have that option.
Boo,
So, are you trying to be incognito using the kaymfischer handle?
Tom and Margaret
Old 10-03-2015, 12:57 PM   #24
Evereddie's Avatar
Originally Posted by gasman94 View Post
Just picked some Prestone up from Family Farm and home @ two for $5. Sale on until tomorrow, if you have one nearby.
Rich
Is that Prestone RV anti-freeze or straight Prestone like for a car. Hope not.
Evereddie is offline   Reply With Quote
Old 10-03-2015, 01:11 PM   #25
BendOrLarry's Avatar
Talking
The point I was trying to make is that if you run enough anti freeze though your pipes the result is enough in the traps, no extra needed. Pour to your hearts content.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 10-03-2015, 01:13 PM   #26
Is the Camco RV antifreeze alcohol-based or non-alcohol?
kluza2786 is offline   Reply With Quote
Old 10-03-2015, 01:14 PM   #27
tmmar's Avatar
Unless you blow out the lines with air before you pump the antifreeze through, the antifreeze in the traps is somewhat diluted. Pouring more straight, undiluted antifreeze into the traps should prevent any issues
Tom and Margaret
Old 10-03-2015, 01:16 PM   #28
tmmar's Avatar
It is a mixture of ethyl alcohol and glycol.
Tom and Margaret
Old 10-03-2015, 01:25 PM   #29
The RV dealer who I bought my TT from offered a winterizing seminar last fall that I attended. They made a pretty big deal about their RV antifreeze being a non-alcohol formulation. Of course theirs was about $ 5.00 or so per gallon - but since it doesn't require very much to winterize I went with theirs.
Old 10-03-2015, 01:53 PM   #30
ChipBruce's Avatar
Gasmsn94: you can't use regular automotive antifreeze in your fresh water lines. It would be toxic/poisonous. You need to use non-toxic RV antifreeze.
Chip Bruce, RPh
Kansas City, MO
ChipBruce is offline   Reply With Quote
