Old 06-20-2015, 05:53 PM   #1
Adding 3rd AC unit to 2014 Berkshire
Hello everyone.
I'm looking to add a 3rd (quieter) AC unit to my 2014 Berkshire 400BH. I live in Austin and we have some pretty intense, humid summers and the 2 (15K BTU) units are simply not cutting it for me.
I've seen some 'old' threads on adding an AC unit to the vent space in the Kitchen area but I'd like to know if there is any new input on the topic.
- Has anyone put a 3rd unit in that location successfully?
- Is there any issue tapping into power and can the coach handle the add on?
- Any recommendation on units that offer a strong cooling function but also quiet?
Thanks.
Brandon
DeepEddyVodka is offline   Reply With Quote
Old 06-20-2015, 06:27 PM   #2
dan-nickie's Avatar
Welcome to the forum.
I have followed a few threads on it but have not read of anyone getting it done yet.
Do it and let us know how it works out.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-20-2015, 06:37 PM   #3
mark0224's Avatar
Instead of adding a roof top one, now this might sound a bit redneck but hear me out. Get one of those floor/window ones and put it somewhere out of the way. Then run an extension out through the slides gap at the bottom of the slide and plug it directly into the pedestal so you don't have to upgrade all the electrical.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 06-20-2015, 06:59 PM   #4
dan-nickie's Avatar
Redneck....
Dan
Old 06-20-2015, 07:34 PM   #5
Brandon,
Be sure you ask about the installation before proceeding. About 2 years ago I thought about doing the same on our 2011. I contacted FR and their recommendation was not to make the installation due to the lack of structure around the vent.
Pat
Cudntherd
2011 Berkshire 390BH-60
cudntherd is offline   Reply With Quote
Old 06-20-2015, 10:48 PM   #6
Do you have a OUTSIDE sun shade on the windshield and side windows. Also do you have sunshade in the slide windows as well as awnings? I found all these are key to cooling your MH. You have two 15000 a/c so you already are ahead of most of us. Adding a third sounds good but make sure they will all run at the same time on the 50amp power you have.
Old 06-20-2015, 10:48 PM   #7
Also a warm welcome to the forum.
Old 06-21-2015, 11:56 AM   #8
Originally Posted by DeepEddyVodka View Post
Hello everyone.
I'm looking to add a 3rd (quieter) AC unit to my 2014 Berkshire 400BH. I live in Austin and we have some pretty intense, humid summers and the 2 (15K BTU) units are simply not cutting it for me. I've seen some 'old' threads on adding an AC unit to the vent space in the Kitchen area but I'd like to know if there is any new input on the topic.- Has anyone put a 3rd unit in that location successfully?- Is there any issue tapping into power and can the coach handle the add on? - Any recommendation on units that offer a strong cooling function but also quiet?
Thanks.Brandon
Two 15K A.C. units are equivalent to a 2.5 Ton home Air Conditioner. Should be plenty of cold air for your Birkshire. I would first have those A.C. units checked out by a technician. They may be low on Freon.
Good luck,
billb800si is offline   Reply With Quote
Old 06-21-2015, 12:04 PM   #9
accumack's Avatar
If you are in hot weather they don't come close to cooling the Berkshire. Our's have a 23 degree differential which is good. When we were in Tuscan the air temp was 108 and we didn't get below 95 inside until 10 at night. The a/c units just can't keep up.
accumack is offline   Reply With Quote
Old 06-21-2015, 12:18 PM   #10
Just curious as to what size A/C units you have. Do you use any sun shades and or awnings. 108 is hot and no comparison to what I have encountered but we have had 95 and very humid with the 13.5 A/C hold the MH to low mid 70's. I almost always get a twenty degree drop. Of course the sun is so much more intense. I have a sun shade or awning on every window. The last thing I need to do is paint the skylight in the shower. There was a post about doing that and I haven't gotten around to it. The guy that posted it used a rattle can white paint used to paint plastic. I get a lot of heat coming in that skylight.
2014, berkshire
