Old 11-26-2015, 04:49 PM   #21
baddmann's Avatar
Here are the pics from my install:
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
baddmann is offline   Reply With Quote
Old 11-26-2015, 07:56 PM   #22
Campin Cajun's Avatar
Adding a front TV
Nice install, looks good.
Y'all see that little white clip attached to those wires in the first picture? That's the rascal that turns off the TV when the ignition is on. Just saying.......
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 11-26-2015, 08:20 PM   #23
Go Seahawks!
Subsailor's Avatar
So, the 120 volt outlet next to that white plug loses power because of the white plug? Or does the factory installed TV have a place to plug that white plug into?
Glenn and Darcy
2013 Berkshire 390RB
2013 Jeep Wrangler (toad)
Pacific Northwest
Subsailor is offline   Reply With Quote
Old 11-26-2015, 08:31 PM   #24
VinceU's Avatar
No mods to TV, just disable outlet with ign.
Old 11-26-2015, 08:46 PM   #25
baddmann's Avatar
Thanks!
I tested the plug before I installed everything and it was hot with engine running. So... If you plug straight into the outlet you should be good.
Also, I added a IR transmitter to the bottom of the TV. That way passengers can use the headphones from the bunk beds to watch TV while I listen to the radio.
Brian and Kelly
Old 11-27-2015, 08:37 AM   #26
Yes the plug is hot with ignition on, that white piece is connected somehow to the ignition and shuts off power to the TV when the ignition is on.
Old 11-27-2015, 08:50 AM   #27
RSchleder's Avatar
Subsailor--sweet rod!!!!! I built a 29 Model A and drove it all over the US to Rod Runs in the late 90's, early 2000's. Had a ball, met lots of great people!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 11-27-2015, 09:14 AM   #28
Go Seahawks!
Subsailor's Avatar
Thanks, the '27 is a lot of fun when it's warmer.
Glenn and Darcy
Pacific Northwest
Old 11-27-2015, 05:54 PM   #29
oldkeywest91's Avatar
From the factory there is a module that is plugged into the AC plug,the white clip is then plugged into module side and tv plugged into front.This is what is disconnected when key turned on.
oldkeywest91 is offline   Reply With Quote
Old 11-28-2015, 09:00 PM   #30
That module is like a relay. When the 12 volt side is energized by turning ignition on, it opens (or breaks) the 110 volt side, so power it interrupted to the TV
Calgary, AB Canada
Ridenfun is online now   Reply With Quote
