Old 08-08-2015, 04:29 PM   #1
Additional A/C
2014 BH400
I'm one of those guys that use the ac in the winter at home.
We are currently glamping in the hot Texas heat (96-103) and the current 2 units cannot catch up until the middle of the night. (Thermostats set at 65, interior temps finally reach 67-69) By early afternoon we are gaining interior temps of 78-80. Doors shut. Both shades drawn.
Will our generator support another ac unit? Or would it be possible to wire for shore power only? (Kitchen vent location)
Should we consider larger units and just stick with 2 units?
2014 Berkshire 400BH-60
2012 MC Ram 2500 6.7 Limited
nastygts is offline   Reply With Quote
Old 08-08-2015, 04:48 PM   #2
2011 Berkshire 390BH-60
TaterColo's Avatar
What I have done when we get back from sightseeing and the coach is hot - even with both rooftop AC going is I start the coach and turn on the MAX AC on the dash. Seem to help.
TaterColo is offline   Reply With Quote
Old 08-08-2015, 05:02 PM   #3
Is this OK to do with shore power plugged in? I'm asking for future knowledge......T.I.A!
Old 08-08-2015, 05:08 PM   #4
TaterColo's Avatar
I've had no issues.
Old 08-08-2015, 08:55 PM   #5
Originally Posted by nastygts View Post
2014 BH400
It's going to be tough getting it cool it that temp. A couple of questions.
1 Do you have a outside sunshade?
If you do do you have it on the drivers side window and the door?
2 do you have awnings on the exposed windows?
3 do you have insulation in the vents?
4 How about the skylight. I have considered painting it white to help with the heat invasion.
5 Do you have 13,500 AC or 15000?
6 When very hot out we open the main vent to allow the cool air to drop down instead of going through the vents. This is only for older MH as the new ones are different.
As far as I have seen there is not a single answer to cooling the MH. All these things I have done and it helps. I guess if you had 3 AC you would not need to worry about it but I don't so keeping the heat out is very important.
Old 08-09-2015, 09:29 PM   #6
Motodad's Avatar
I just got finished today. Bought some reflectix from Home Depot and made my own shade for the front and drivers side windows. It was 105 in east tx today. My berk is usually around 100 with acs off in my driveway. I checked it at 6pm and it was 87deg. It made a big difference. I have a lot of reflectix left. Where else can I put it to help? I have 2 13550 units and I'm thinking about getting a stand alone AC as well. I will get it to 70 on a 105deg day
Motodad is offline   Reply With Quote
Old 08-11-2015, 10:19 PM   #7
1 Do you have a outside sunshade? Just the awnings
2 do you have awnings on the exposed windows? No
3 do you have insulation in the vents? Whatever comes from the factory
4 How about the skylight. I have considered painting it white to help with the heat invasion. I am now considering this
5 Do you have 13,500 AC or 15000? 13,500
6 When very hot out we open the main vent to allow the cool air to drop down instead of going through the vents. This is only for older MH as the new ones are different. Yes, I used the dump vents
I kept all the sunshades and night shades closed. I am doing my research now as to what films and "blockers" while parked. I now understand why full timers migrate elsewhere during the hot summer months. LOL
We made it back home yesterday evening and parked under covered carport. I left the front unit on with the thermostat set at 73.
Stopped by this afternoon while the temp was 102ish here......walked in.....nice and cool (73). I cant believe how much heat soaks up in these things.
What exactly is the exhaust fan( kitchen area) tied into a separate thermostat used for anyways?
Old 08-11-2015, 10:22 PM   #8
I brainstormed this stuff on the drive home. I thought about trimming nicely for the front windows and fabbing up some HD suction cups to hold up as close to the glass as possible.
Old 09-22-2015, 08:39 PM   #9
Motodad's Avatar
I used 9lb magnets. About the size of a watch battery. Glued them to the windows and to the reflectix. Works great. I'm eventually going to make them work on the outside in stead of the inside.
Old 09-28-2015, 03:10 PM   #10
jmgllt's Avatar
Following
jmgllt is offline   Reply With Quote
Old 10-01-2015, 11:26 AM   #11
Don't know your size of A/C. But what i did was upgrade the front A/C from a 13,500 to a 15,000 A/C. And in the back is the 13,500. Was in Az. this summer and I could keep it in the cool 78* was very comfortable.
outloud is offline   Reply With Quote
Old 10-19-2015, 09:37 PM   #12
fredhardy's Avatar
I touched base with MagnaShade today. $520 for a Berkshire exterior shade. I've read they do a great job in lowering heat in the rigs.
fredhardy is offline   Reply With Quote
Old 10-19-2015, 11:24 PM   #13
nathantoensing's Avatar
Just got ours installed this weekend...6.5 weeks to make with the digital print at $975!!! Pricey but well worth it here in Tucson. We noticed the reduction in heat inside the Berk immediately!!!
Name:	ImageUploadedByForest River Forums1445314940.137117.jpg
--Nathan
2016 38a
--Nathan
2016 38a
nathantoensing is offline   Reply With Quote
Old 10-20-2015, 04:48 AM   #14
975.00 ! Wow, no wonder the big eyes.
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-20-2015, 07:36 AM   #15
You heard right. I love ours. So easy to use. Never need a ladder.
