Old 08-26-2015, 09:37 AM   #1
DJP6371's Avatar
Air bag lift problem 390QS
Have had a couple of incidents where the airbags did not lift up on starting the engine after sitting for a couple days.
This happened a couple of years ago, and I shut everything off, put the stabilizers back down, raised them again and started the coach and the bags deployed.
I phoned Freightliner and they told me that there was a certain window of opportunity between lifting the stabilizers and starting the engine before the electrical charge that switches the air valve around, activates.
This happened again to me this morning. Has anyone else experienced this issue?
Sent from my iPhone 'cause I'm probably out in the RV!
DJP6371 is offline   Reply With Quote
Old 08-26-2015, 09:46 AM   #2
I start my engine and wait till the air has full pressure then lift my jacks... Some tell us here that there is a valve that is stuck and more pressure flips it over... For what it's worth.
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 08-26-2015, 09:46 AM   #3
I have it happen every now and then. I usually just turn the Equilizer jacks on and retract all. After this it will lift the front of the coach.
-David
trekdave42 is offline   Reply With Quote
Old 08-26-2015, 05:23 PM   #4
Campin Cajun's Avatar
Same as trekdave 42, I've had it happen after my coach sits idle for a few weeks. Like Dave I just hit the all retract button and I'm good to go.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 08-26-2015, 07:19 PM   #5
dan-nickie's Avatar
I learned this on the forum before I even picked up my Berkshire.
So I have never had the problem.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-27-2015, 09:17 AM   #6
AREA51's Avatar
This happens somewhat often. I just hit the retract button a couple of times, light up the engine and walk around the coach to be sure of the height between the wheels and the wheel well opening.
GOOD LUCK
AREA51
AREA51 is offline   Reply With Quote
Old 08-27-2015, 02:24 PM   #7
Just Dreamin
dreamin533's Avatar
I haven't had it happen yet. What I would like to have is what they put on the Fleetwoods, it's a switch on the dash (same as an eighteen wheeler) that allows you to dump the air bags before you level and even air the bags up before you retract. I had a Fleetwood and really appreciated that piece of equipment.
dreamin533 is offline   Reply With Quote
Old 08-31-2015, 12:22 PM   #8
I do what TekDave42 does...I actually drove away once and got the rough ride of my life...scared the heck out of me...then when I shut down and restarted they inflated...later, I had this happen when I was at a campsite, noticed they didn't inflate and just hit retract all and when it was done, they started inflating.
smo99 is offline   Reply With Quote
