Old 06-20-2013, 08:38 AM   #1
Scokat's Avatar
Air Bags
The wife and I took the rig out for a drive this past weekend to run her up to temp and do a spring shakedown cruise. I parked the rig but didnt dump any air. I noticed last night that the top of the wheel well is even with the top of the tire, like when the levelers are down. Normal running, about 5-6 inches above the tires up front. However my levelers are up and I dont remember the coach sitting so low. I thought the air bags held the air until you put the levelers down and dump the system. Is this normal and I just havent been looking at the rv for awhile.
2013 Berkshire 390RB DP/360--(Toad)2009 Trailblazer.
3rd generation Disabled Veteran, oldest son is 4th Generation Disabled Veteran...its a family tradition.
Scokat is offline   Reply With Quote
Old 06-20-2013, 08:58 AM   #2
tmmar's Avatar
The air bags will lose air by them selves over time. But in your situation, it seems that you are losing air more quickly than usual. I would run the coach and so that the air bags fill up and look at it again in a few days. If the same thing happens you may want to get it checked.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-20-2013, 02:29 PM   #3
EJM4's Avatar
Try running the coach till both air tanks are full. Turn the the power on to the jacks and press the raise all jacks button. - That should fill the bags.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
