Originally Posted by klucas
I am getting a pull to the right under braking. I read a few articals saying the slack adjusters may need attention. Apparently even with auto slack adjusters there is a way to reset the adjustment by fanning the brake ect. Curious if anyone has attempted it and if it worked.
I'm not sure about 'resetting' the adjustment, but I learned the procedure for automatically adjusting them on here last year and it has helped with the general feel of the brakes. Forgive me if you already know this.
After starting up and only on level ground/pavment:
1. Transmission in neutral
2. Release the parking brake
3. Depress the brake pedal fully (with a little force) 3- 4 times.
I had been noticing my brakes didn't seem quite as good as when I got it new. After starting to use this procedure regularly the brakes feel like new again.
