Old 06-20-2014, 06:37 PM   #11
Originally Posted by I-RV View Post
X2 to being a slow process for topping off MHZ tires. It would be good to have a compressor with a pressure about 30 lbs above the pressure you are trying to reach. That makes the filling go faster. Unfortunately, if say you want 110 lbs in your tires, the pressure out of the MH isn't going be too much higher. A trick to get the MH pressure up, is to deplete some air. One way is to mash on the brakes several times (of course with engine running). This depletes air and causes the compressor to build up air to its limit. Then you top your tires. Hope it works for you!
X3 on the slow. But since the normal working pressure of the air system is around 135 lbs when the governor "blows off" you will easily go to 110+ lbs.
I do it all the time.
Boowho??
boowho is offline   Reply With Quote
Old 06-20-2014, 07:52 PM   #12
Thanks for the info. And FYI, mine did come with a quick connect. I wonder why some didn't get one?
JJvike is offline   Reply With Quote
Old 06-20-2014, 11:05 PM   #13
2011 Berkshire 390BH
Superchief's Avatar
Cause they got Tom's "Happy Birthday to me" gifts! 😂 Happy Birthday to Me!!
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
Old 06-20-2014, 11:25 PM   #14
Iwannacamp's Avatar
Lol. I got a "happy Father's Day" to me. New converter/charger. Christmas was happy to me...new sewer hose and x-chocks. She new E XACTLY what I wanted. It's a miracle. Ha ha.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
