06-15-2014, 06:32 PM
Air compressor
Any know f we have a connection to the compressed air via a quick disconnect? I have a 400BH and thought we did but it's propane... Not good to fill pool toys! Wrong size too for a reason I'm sure.
Jc
2014 400BH-60
06-15-2014, 06:44 PM
Berkshire 390QS
In ours, the air is in the gererator area up front, the propane one is in a rear bay just ahead of the water service door.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
06-15-2014, 08:16 PM
Like NO3put said, slide open your generator, duck down, look up and to the right. There's the brass air quick connect.
2013 Berkshire 390BH
06-15-2014, 09:30 PM
You rock! Thanks
Jc
2014 400BH-60
06-15-2014, 09:34 PM
Upper right firewall above the generator..... In front of area where steering wheel is.... It may not have the quick connect on it... Mine didn't..... If not, it will be a piece with six plugs screwed into it.... Remove one of the plugs, buy a quick connector and install..... Just make sure you have emptied the air tank BEFORE you unscrew one of the plugs or you might get a really big surprise.....
06-16-2014, 01:03 AM
Yep, right there and had the QD. Thanks again.
Jc
2014 400BH-60
06-17-2014, 06:54 PM
Anyone have an idea what kind of psi the system can produce? Will it inflate a tire on the RV?
06-17-2014, 07:00 PM
Engineer of Crazy Train
UPDATE: High Pressure RV Tire Inflation: http://youtu.be/n5fK54DKWP0
HOW TO: Inflate High Pressure RV Tires: http://youtu.be/QDOqCk6dTuo
Sent from my Samsung Galaxy Note 2 using the FRF mobile app.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
06-17-2014, 08:01 PM
Berkshire 390QS
I've tryed to top off the tires using the onboard air, a slow process but will works however you need to keep your engine running. It's great to kids toys etc. You air presure gages will let you know about how much presure you have.
06-20-2014, 12:18 PM
X2 to being a slow process for topping off MHZ tires. It would be good to have a compressor with a pressure about 30 lbs above the pressure you are trying to reach. That makes the filling go faster. Unfortunately, if say you want 110 lbs in your tires, the pressure out of the MH isn't going be too much higher. A trick to get the MH pressure up, is to deplete some air. One way is to mash on the brakes several times (of course with engine running). This depletes air and causes the compressor to build up air to its limit. Then you top your tires. Hope it works for you!
Gale & Hank- 2012 Berkshire 390BH
06-20-2014, 06:37 PM
X3 on the slow. But since the normal working pressure of the air system is around 135 lbs when the governor "blows off" you will easily go to 110+ lbs.
I do it all the time.
Boowho??
06-20-2014, 07:52 PM
Thanks for the info. And FYI, mine did come with a quick connect. I wonder why some didn't get one?
06-20-2014, 11:05 PM
2011 Berkshire 390BH
Cause they got Tom's "Happy Birthday to me" gifts! 😂 http://www.forestriverforums.com/for...ad.php?t=62742
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
06-20-2014, 11:25 PM
Lol. I got a "happy Father's Day" to me. New converter/charger. Christmas was happy to me...new sewer hose and x-chocks. She new E XACTLY what I wanted. It's a miracle. Ha ha.
2017 Puma 297RLSS
