Old 06-15-2015, 06:52 PM   #1
EJM4's Avatar
Air Conditioner; Model #
Does anyone have the model # for our a/c's?
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 06-15-2015, 07:10 PM   #2
TURBS's Avatar
If you pull open the filter grate you'll find the model and serial numbers I believe.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-15-2015, 07:13 PM   #3
dan-nickie's Avatar
Is it the Dometic Penquin II Low Profile.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-15-2015, 07:24 PM   #4
EJM4's Avatar
Looks like it.
My coach is in the repair shop for trans service and wanted to purchase a 3rd a/c and wanted to get the same model.
Earl
Old 06-16-2015, 08:03 AM   #5
tmmar's Avatar
There was a discussion about adding a 3rd air conditioner. Do a search and you should find it. If I remember correctly, I believe that FR doesn't recommend it because of weight on the roof and power issues.
Tom and Margaret
2014 Berkshire 390bh-60
tmmar is online now   Reply With Quote
Old 06-16-2015, 08:33 AM   #6
EJM4's Avatar
I have read them and plan on going ahead with it. I don't buy into the theory of weight on the roof. I would imagine a person walking on the roof would be heavier than a third air conditioner sitting up there. I would assume FR's issue is using the vent / fan opening for the a/c and someone cutting another hole in the roof to replace the fan?
The others who have installed them seem to have good success doing so.
Earl
Old 06-16-2015, 02:51 PM   #7
We don't get into super hot temps. About the warmest was 95 in FL but with the shades and covers we were able to keep our 390RB in the low 70's.
Old 06-16-2015, 03:00 PM   #8
Would love to add 3rd Ac! Az gets hot!
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 06-16-2015, 03:27 PM   #9
heavynlori's Avatar
There is most likely extra bracing in the roof for the AC units but doubt that extra bracing is used around the regular roof vent openings....
That is probably the issue FR has with adding a third unit if roof was not constructed for one in the future ... You are lucky if you get the bedroom second AC option as in wire and bracing already there when you want to install AC unit
heavynlori is offline   Reply With Quote
Old 06-16-2015, 06:41 PM   #10
Mmnsc's Avatar
Name:	ImageUploadedByForest River Forums1434497938.249418.jpg
EMJ4
Attached is a photo of my front high capacity A/C with Heat Pump. Hope this helps
Mmnsc is offline   Reply With Quote
air conditioner, modifications
