Old 04-22-2017, 12:35 PM   #1
RKC02's Avatar
Air Conditioner Problems
My rear A/C unit quit cooling a few months ago and I was able to repair it by replacing the start capacitor (smaller of the two). Now the unit will start, compressor comes on after 10 seconds or so, runs for 60 seconds then shuts off. After 1 or 2 minutes the unit repeats the process. I did try setting the thermostat as low as it would go to see if it was a temperature differential or sensor but no joy.
Only components left that I can replace are the run capacitor and circuit board. After that I guess it's new unit time.
If anyone have any insights on this problem please let me know.
My coach is a 2014 Berk 390 RB-60 and it was built late 2013-early 2014. Would think the air conditioner could last more than 3 years but may be time for an upgrade to 15k units.
Thanks in advance for any help or advice.
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 04-23-2017, 05:53 AM   #2
replace the run capacitor and make sure the start capacitor you put in was correct.
What your describing is the compressor running- but then going off on its internal overload. This responds to heat (not running long enough for that) and amp draw.
If the capacitors do not if it, I believe you would have a bad compressor.
2012 390BH
dave-g is offline   Reply With Quote
Old 04-23-2017, 06:16 AM   #3
RKC02's Avatar
dave-g: Thanks for the advice and assist. Hopefully the local dealer will have the run cap in stock and I can do the swap real soon. I will post the results either way. Thanks again.
Old 04-23-2017, 04:41 PM   #4
RKC02's Avatar
dave-g/ all: I turned the unit on to fan only and manual setting to medium (instead of auto). The compressor came on, went off twice, then stayed on (!!?!!).
Very pleased with result since it us hot & humid here in Florida, but stymied as to cause. Guess the run capacitor could still be the culprit but also wondering if the circuit board is questionable. I am assuming (yeah, I know...), the compressor is not the problem since it is still cranking.
Any ideas?
Old 04-23-2017, 06:34 PM   #5
Retired JSO's Avatar
The newer domestic A/C's will cycle the compressor off for a few seconds and the fan will usually change speeds when the fan switch is in the auto position and the temperature differential is about + or - 4 degrees. Mine does it especially right after arrival at a campsite in hot summer temps. I usually flip the fan switch to high.
Retired JSO is offline   Reply With Quote
Old 04-24-2017, 04:34 PM   #6
Dragonship Captain
Oscarvan's Avatar
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 04-24-2017, 04:44 PM   #7
Iwannacamp's Avatar
Not calling you wrong... but why?
2017 Puma 297RLSS
Old 04-24-2017, 08:48 PM   #8
I don't know but it's here. http://www.forestriverforums.com/for...mes-77855.html
air conditioner
