Old 03-09-2014, 03:53 PM   #1
Campin Cajun's Avatar
Air Down
I made some blocks to put under my jacks for when I leave my coach stored. I wanted to try them out yesterday but realized I don't know how to air down the bags without autoleveling also. I did get it to work but I was hitting buttons left and right with alarms going off.
Anybody know the correct procedure to air down?
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 03-09-2014, 05:03 PM   #2
EJM4's Avatar
Why would you want to deflate the air bags when you store the unit? The air bags are designed to be inflated.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 03-09-2014, 05:39 PM   #3
tmmar's Avatar
Cajun,
I just put the blocks under the jacks and eventually the air will bleed out of the bags and the coach will settle on the blocks. It may take a couple of weeks but I didn't think it was necessary to fully deflate the air bags all at once.
Tom
Tom and Margaret
2014 Berkshire 390bh-60
Old 03-09-2014, 07:23 PM   #4
klucas's Avatar
You can push the auto level. After a few seconds hit any other button. It continues the deflate but will stop the jacks. It has worked for me.
klucas is offline   Reply With Quote
Old 03-09-2014, 07:51 PM   #5
Air Down
EJM I work 2 weeks away from home, then two weeks off at home. My bags are usually deflated when I get back home. It's not good for the bags to deflate and be sitting empty with all the weight of the coach on them. Hence the blocks. I made them to be about an inch shorter than where the jacks are when the bags are aired up. When they start bleeding down they will contact the blocks keeping the weight of the coach on the jacks instead of the empty air bags.
Tom mine do the same I just wanted to test my blocks to make sure they would hold together
klucas, thanks. I knew that was covered in my PDI, but I forgot what the guy said.
