Old 07-06-2019, 09:40 AM   #1
Air Dump Switch
Can anyone share experience with air dump process on 2014 FR Berkshire 39rb? It seems some RV's have the separate switch and others do not. So, when parked and sliders in, how does one get the air dump to employ w/o setting self leveling system switch to "on"
Ribko is offline   Reply With Quote
Old 07-18-2019, 12:19 PM   #2
Turn on the self levelling panel. Then turn it off before the jacks start to descend.
When you start again, there is a chance that this procedure has stopped your air bags from inflating. To reset the switch to allow your air bags to inflate again, start the engine to fill the air tanks. Turn off the engine and hit the button to retract jacks. Then start the engine and make sure the coach rises as the bags fill. If this doesn't work, you need to extend the jacks and then retract them. Then restart the engine.
The important thing is that you need to have air pressure in the system within 2 minutes of retracting the jacks to turn on an air switch that lets you fill the air bags.
–Gordon
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...qs-191578.html
2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
switch
