Old 04-02-2019, 08:52 PM   #1
air horn activates on it's own
Our 2011 Berkshire 360QS has started blowing the air horn intermittently on it's own. I turned off both main battery switches in battery compartment, but it will still blow every once in a while. Any one have any ideas? Thanks.
strato is offline   Reply With Quote
Old 04-02-2019, 09:19 PM   #2
Solenoid failure ? or beginning to fail ?
TheWolfPaq82 is offline   Reply With Quote
Old 04-03-2019, 09:21 PM   #3
Ours did the same. Was the steering wheel clockspring.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 04-03-2019, 10:43 PM   #4
Dragonship Captain
Oscarvan's Avatar
That makes sense.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 04-04-2019, 01:20 PM   #5
I'd get that taken care of quick before it happens behind a pack of Hells Angels! :-)
breezyhillfarm is offline   Reply With Quote
Old 04-04-2019, 02:16 PM   #6
Or worse yet, a couple of stirred up gray haired ladies from the neighborhood.
2016 Berkshire XL 40A towing 2016 Jeep Wrangler.
Prior to this Jayco fifth wheel: 24' Eagle, 30' Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 04-04-2019, 07:42 PM   #7
Dragonship Captain
Oscarvan's Avatar
There is something worse....
Old 04-04-2019, 07:54 PM   #8
yes, indeed sir.
Old 04-08-2019, 08:39 AM   #9
BobbyJ
Bobbyj's Avatar
Had the same problem. Switched over to the auto horn to stop it. Problem fixed at Freightliner: Metal shavings shorting the horn in the steering column.
Bobbyj is offline   Reply With Quote
