Old 10-29-2015, 01:30 PM   #11
I only asked about the map lights as I thought they might be in the same fuse.
Old 10-29-2015, 01:46 PM   #12
Silly me. I still don't have map lights😂😇
Paul
Paulie Boy is offline   Reply With Quote
Old 10-30-2015, 08:37 PM   #13
Campin Cajun's Avatar
Does the DNR light up during the daylight? If so, this is an odd problem. Maybe you should give a call to the FL Hotline.
Sent from my iPad using Tapatalk
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-30-2015, 08:49 PM   #14
jmgllt's Avatar
Allison 2500 transmission display
Ok maybe there is a misunderstanding, the red D showing what gear the trans is in shows but the buttons DNR, is what I was wondering if they where back lit at night.
jmgllt is offline   Reply With Quote
Old 10-31-2015, 11:48 AM   #15
Now I see said the blind man. There are 4 allen head bolts that hold that control panel down. I would back those out and see if you can tell if there is a light bulb of some sort in there.
Old 11-02-2015, 07:41 PM   #16
jmgllt's Avatar
Ok update, took the screws out looked at the back of the shifter and no light to be seen just two plugs. Any help would be appreciated.
Old 11-03-2015, 06:16 PM   #17
jmgllt's Avatar
New update, I talked to Allison and I have to bring it to the shop so they can fix it. Thanks for all the help it was appreciated!
Old 11-03-2015, 07:24 PM   #18
Did they tell you what was causing it?
Old 11-03-2015, 07:43 PM   #19
jmgllt's Avatar
No just talked to customer service I'll have to have a technician look at it
Old 11-03-2015, 07:51 PM   #20
Gotcha, well let us know what they find.
