Old 11-04-2015, 10:28 PM   #21
Ok I tried to post a video but I can't figure it out. I was looking at the display and the RND lights up in a yellow light. The dimmer roller next to the headlight switch controls the dimmer function. Also it controls the display on the dash and the map lights. I would guess that either a bulb is blown out or a fuse is blown or the roller dimmer switch is bad.
Old 11-04-2015, 10:38 PM   #22
jmgllt's Avatar
Yep your right, that's how it should work. I talk to the Allison shop, the trans is still under warranty. They told me to get them the part # off the shifter and the serial number off the trans. They will order the part( shifter), and when the part comes in they will swap it out!
jmgllt is offline   Reply With Quote
