Old 10-28-2015, 08:54 PM   #1
jmgllt's Avatar
Allison 2500 transmission display
I bought my Berkshire used, and have problems seeing the RND shift modes at night. Should it be back lit with the head lights?
jmgllt is offline   Reply With Quote
Old 10-28-2015, 09:00 PM   #2
It should light up brightly. Turn the roller switch next to the headlight switch.
Old 10-28-2015, 09:13 PM   #3
jmgllt's Avatar
Yea that's what I thought, tried that but got nothing. I'm thinking I might have a light bulb burnt out.
Old 10-28-2015, 09:25 PM   #4
Odd that should not just be one bulb. Maybe but I think there are several in there. Maybe a fuse? I would look at the 12v compartment below the driver.
Old 10-28-2015, 09:26 PM   #5
Still thinking here do you have map lights? Do they work.
Old 10-28-2015, 10:06 PM   #6
jmgllt's Avatar
Yes the map lights do work
Old 10-28-2015, 10:21 PM   #7
jmgllt's Avatar
Old 10-28-2015, 10:24 PM   #8
I'm stumped. I'll look at mine in the morning. Someone has had this happen I would bet they will have a fix. Sorry.
Old 10-29-2015, 07:44 AM   #9
My 2014 390-BH 60 doesn't have map lights😂
Paul
Paulie Boy is offline   Reply With Quote
Old 10-29-2015, 01:05 PM   #10
Paul
Ditto, but who reads maps anymore? Didn't they follow phone books ?
Joe & Lori
2014 Berkshire 390 RB-40
5456Mich is offline   Reply With Quote
Old 10-29-2015, 01:30 PM   #11
I only asked about the map lights as I thought they might be in the same fuse.
Old 10-29-2015, 01:46 PM   #12
Silly me. I still don't have map lights😂😇
Paul
Old 10-30-2015, 08:37 PM   #13
Campin Cajun's Avatar
Does the DNR light up during the daylight? If so, this is an odd problem. Maybe you should give a call to the FL Hotline.
Sent from my iPad using Tapatalk
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-30-2015, 08:49 PM   #14
jmgllt's Avatar
Ok maybe there is a misunderstanding, the red D showing what gear the trans is in shows but the buttons DNR, is what I was wondering if they where back lit at night.
Old 10-31-2015, 11:48 AM   #15
Now I see said the blind man. There are 4 allen head bolts that hold that control panel down. I would back those out and see if you can tell if there is a light bulb of some sort in there.
Old 11-02-2015, 08:41 PM   #16
jmgllt's Avatar
Ok update, took the screws out looked at the back of the shifter and no light to be seen just two plugs. Any help would be appreciated.
Old 11-03-2015, 07:16 PM   #17
jmgllt's Avatar
New update, I talked to Allison and I have to bring it to the shop so they can fix it. Thanks for all the help it was appreciated!
Old 11-03-2015, 08:24 PM   #18
Did they tell you what was causing it?
Old 11-03-2015, 08:43 PM   #19
jmgllt's Avatar
No just talked to customer service I'll have to have a technician look at it
Old 11-03-2015, 08:51 PM   #20
Gotcha, well let us know what they find.
