Old 08-28-2016, 09:27 AM   #1
klucas's Avatar
Allison 3000 transmission service.
I am going to change my transmission filters and fluid on my 2012 bh390-60 with Allison 3000 transmission. The local freightliner told me they can't look up the part numbers for the filters I need I have to bring them in to match up what they have in stock. Does anyone happen to know the part numbers? Also how much fluid did you use? Any info would be great.
klucas is offline   Reply With Quote
Old 08-29-2016, 04:53 AM   #2
2014 360 QL
po 185's Avatar
it would be best to change the fluid, if you have not done it yet
2014 360 ql
po 185 is online now   Reply With Quote
Old 08-29-2016, 05:36 AM   #3
ilmor's Avatar
Have you tried getting the info from their website?
Parts - Service
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-29-2016, 04:58 PM   #4
The part number is in the manual. Also there should be a magnet on the filter they will not be on the new filter. When I did it I filled the filter with fluid and checked the level after I ran it.
Mike
mcomer is offline   Reply With Quote
Old 08-29-2016, 05:13 PM   #5
klucas's Avatar
Mine has 2 internal filters. I am surprised the freightliner place couldn't look up the part number. I will get the serial number and look it up on the web site as suggested above.
Old 09-26-2016, 11:01 AM   #6
EJM4's Avatar
I had mine serviced last year at the local Allison dealer and they told me there are no internal filters in mine...
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 09-26-2016, 11:43 AM   #7
klucas's Avatar
If you have the 360 Cummins with the 3000mh trans there are two internal filters. The 340 Cummins with the 2500 trans has an external filter I believe.
Old 09-26-2016, 04:21 PM   #8
Phil57's Avatar
2500 has internal and a small external spin on.
Phil and Dianna
2011 Berkshire 390 RB
service
