Old 01-14-2016, 07:38 PM   #1
DJP6371's Avatar
Allison Transmission filter change
I note that I am due for a transmission filter change on my 2011 Berk 390QS.
Has anyone done this and is it a difficult procedure? I checked around on Youtube and didn't find any tutorials.
DJP6371 is offline   Reply With Quote
Old 01-14-2016, 07:45 PM   #2
Campin Cajun's Avatar
Screw it off and replace with new. Because of the positioning of the filter no oil will leak out.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 01-14-2016, 08:02 PM   #3
Kenny kustom's Avatar
If you do have a spin on trans filter.
Change it every oil change.
For the cost of the filter, and a splash of fluid, it's good insurance!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 01-15-2016, 07:43 AM   #4
silver's Avatar
I have read this thread and not seen a complete answer. It is very easy.
If you have the 2500 transmission the filter simply spins on under the transmission. As stated before you will only loose the fluid in the filter. Look under the coach and you will see the filter.
If you have a 3000 transmission there are two filters. They are under two caps that must be removed on the bottom of the transmission. Again you should not loose any fluid. Remove the caps, take out the old filters and replace with new.
You might wand to run the back wheels up on boards. DO NOT WORK UNDER COACH UP ON ITS JACKS. if hydraulics fall you are dead.
To the rest of you why not answer the guys question rather than respond with all the bickering??
silver is offline   Reply With Quote
Old 01-15-2016, 08:00 AM   #5
Gravity challenged
Bob_Loblaw's Avatar
Great information silver.
If the Allison 2500/3500 spin on filter is similar to the Allison 1000, you may see a magnetic doughnut stuck to the spin on filter when removed. If not check the bottom of the trans where the filter sits.
Do not throw this away! Clean and replace with new filter.
Jim & Susan
2017 Flagstaff 832OKBS - Days camped 2018: 7
2013 Silverado 2500HD LTZ Duramax
Try to learn something about everything and everything about something. - Thomas Henry Huxley
Bob_Loblaw is offline   Reply With Quote
Old 01-15-2016, 08:28 AM   #6
Bluepill's Avatar
The two internal filters on my 3000MH are under a bolt-on plate. The nasty thing is that the sealing is done by old-fashioned flat gaskets, not the more modern o-rings. I changed the filters after 3 years, and spent most of the day removing the gaskets. Spray on some gasket remover, wait 20 minutes, carefully remove a bit of loose material. Repeat and repeat. Not fun.
The bottom line here is that you should probably not attempt an internal filter change if you are on a tight schedule, just in case you find the same setup.
2008 Itasca Meridian 37H
Old 01-15-2016, 04:53 PM   #7
Platokidd's Avatar
This thread needs a cooling off
site team
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 01-15-2016, 05:32 PM   #8
Platokidd's Avatar
Exclamation site team warning
The site team has done a clean up on this thread. So if your posting is gone you know why.
We take the "be nice" rule VERY seriously!We do not tolerate any rudeness!
Thank you
Site team
nights of camping
Seasonal
